A "knocking" sound when i push accelerator
Old Oct 10, 2003 | 11:08 PM
Eric95se's Avatar
I have a 95 5spd with an ACT street disc clutch. I have had this setup for over a year and a half with little or no problems. However, now when I push the pedal down and the car is in gear I get a knock coming from under the hood. The knock also occurs when i take my foot off the gas. It does not happen when I rev the engine in neutral (leads me to believe it is in the tranny). Nissan dealer told me it was the flywheel but didn't want to charge me the labor to take tranny apart and find out. I'm worried! I don't want to be doing more damage to the car. Please help.
Eric
Old Oct 10, 2003 | 11:27 PM
DoGGy
sounds like a bad knock sensor. im not sure tho
Old Oct 10, 2003 | 11:49 PM
Nismotic's Avatar
Always sunny in philly
werd. have u had loss of gas mileage? loss of power? check yo' knock sensor.
Old Oct 11, 2003 | 06:13 AM
Kevlo911's Avatar
Kevlo for President
KNOCK SENSOR makes no noise, it detects pings/knocks from the engine. i believe he is a hearing a different type of knock. can u hear it at low speeds? can u tell which side on the engine bay its comming from?
Old Oct 11, 2003 | 10:13 AM
paul's Avatar
I recently installed a Bully stage 1 clutch and I also get a pop sound that seems to be coming from behind the clutch pedals (behing the firewall). Anyone know what that pop sound is?
Paul
Old Oct 11, 2003 | 01:16 PM
Eric95se's Avatar
I know it's not the knock sensor. I can't pinpoint what part of the bay it is coming from but I can really hear it at low speeds, but i can tell that it is doing it in 2nd or 3rd, but 4 and 5 exhaust and intake drown it out. Any other ideas?
Old Oct 11, 2003 | 01:19 PM
Tight_Whip's Avatar
I know exactly what it is, same thing happened to my maxima. It's proble your Engine Mounts and/or Your transmission mounts, it's costly to repair around $600 for me when i needed both Engine and Transmission mounts.
Old Oct 11, 2003 | 03:37 PM
Scruit's Avatar
U wanna try me young boy?
Originally Posted by Tight_Whip
It's proble your Engine Mounts and/or Your transmission mounts.
1234567890
Old Oct 11, 2003 | 03:43 PM
SXN's Avatar
SXN
it monitors minute knocking in the engine... this doesnt sound like it
Old Oct 12, 2003 | 08:10 AM
Eric95se's Avatar
So it is one or more of the mounts, i guess. What exactly is wrong with it? Is it loose or completley wrecked? I figured that I would be able to hear the motor mount shift just by revving the engine un neutral, but as I said before it only happens when a gear is engaged, si it leads me to believe that it is a transmission mount, i guess....
Old Oct 12, 2003 | 08:43 AM
Tight_Whip's Avatar
Bring your car in and tell them to check your Engine & Transmission Mounts. I belive that it is etheir or both. The same exact thing happened to my car as you explained it.
Old Oct 12, 2003 | 11:53 AM
chris j vurnis's Avatar
My car produced a very similar noise and symptoms that you describe.
The noise appeared to be coming from around the firewall or underneath the car. It turned out to be a loose front wheel bearing.
I would suggest checking front wheel bearings in addition to the engine mounts.
Mahmuth
Aug 16, 2024 08:23 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
