MAF Sensor issue
Old Oct 12, 2003 | 10:57 AM
maxima_million's Avatar
MAF Sensor issue
I checked the ECU and got 0102 - Mass Air Flow Sensor. I then checked the wires from the top of the engine and it looks fine. All connections seem to be made. The only thing I did recently over the summer was to clean the throttle body and never got an error code afterwards so I'm ruling that out as a cause. What else could I check to make sure it truly is the MAF sensor? I don't have a voltmeter but if I got one, how would I use it to check?
Thanks in advance!
Old Oct 12, 2003 | 11:01 AM
Kevlo911's Avatar
Kevlo for President
This malfunction is detected when an out-of-range voltage is sent to the ECM. That voltage might be too high or too low.
a) An excessively high voltage from the MAFS is sent when the engine is not running.
b) An excessively high voltage from the MAFS is sent under light load driving conditions.
Possible causes include...
- Harness or connectors (the sensor circuit is open or shorted.)
- Faulty MAFS
c) An excessively low voltage from the MAFS is sent when the engine is not running.
d) An excessively low voltage from the MAFS is sent under heavy load driving conditions.
- Intake air leaks
- Faulty MAFS
With DTC 0102 the ECM is supposed to switch into Fail Safe mode and limit engine speed to 2400 rpm.
search for hte maf sensor ground mod
Old Oct 12, 2003 | 11:09 AM
Thanks for the info. You would not happen to know any issues arising from doing the MAF sensor ground mod? Could I mess anything else up since the MAF has input to the air/fuel mixture?
Old Oct 12, 2003 | 11:13 AM
Kevlo911's Avatar
Kevlo for President
no it won't mess anything up, all you are going to do is re-do the ground to the maf sensor
also clean ur maf sensor with rubbing alcahol and a Q-tip
after all that reset ur ECU
Old Oct 12, 2003 | 11:20 AM
How would I clean the MAF Sensor? I'm asssuming if I disconnect it from the air filter housing, I clean a sensor on the inside? Or the black square on the top?
Old Oct 12, 2003 | 11:22 AM
Oh yea, I should add that the car has no problems (RPM limitations) since I got the error code. I'm assuming again that it's a false reading.... hopefully a simple cleaning will fix it!
Old Oct 12, 2003 | 11:23 AM
Kevlo911's Avatar
Kevlo for President
inside hte circle where the air passes into it, u will see a small elment in the middle - that is what u clean
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
lux97Max
Sep 4, 2015 05:42 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
