Must I align the front end after strut/spring replacement?
I just finished installing H&R's on my 2 month old KYB's. Also replaced be KYB isolators with OEM. The problem I had with rubber on rubber noise when turning the wheel at very slow speeds is gone, problem was with the KYB isolators which are different than the OEM. Bottom rubber piece is wafered on the OEM and straight round on the KYB's.
Anyway, I followed the OEM instructions exactly including setting the car in unladden position when tightening the strut shaft bolts. I also installed 18s afterwards.
My car rides beautifully. Doesn't pull left or right, just goes straight down the road. Other than a little more tire noise I now get with the 18's, I'm totally satisfied with the drop and ride.
Noticed a few more rattles in the car on bumpy roads that I'd never noticed before, suppose it's due to the stiffer springs. This is maybe why I've heard so many people complain of rattles in these cars; I'd previously not noticed significant rattles with the stock suspension.
So my question is: If the front end feels right, should I take the car to have it aligned anyway?
Originally posted by plrod Black 95 SE
... So my question is: If the front end feels right, should I take the car to have it aligned anyway?
Alignment? Yes Sir.
Changed my mind...
Originally posted by dch95
... Yes you should because here is what has happened. I know this from personal experience. After you lowered the car, you did effected the toe in/out characteristics of the alignment. ...
I recommend you let the springs settle before you align the car. Your "toe" will be off. What I noticed after the spring install was more "dartiness" with steering input even though the car tracked fine. After the spring settled (~3 weeks), I got the car aligned and the toe was quite bit off. After the alignment, the steering felt much firmer.
Dave
Dave
Should i
I just bought Intrax spring and will be putting on 16" Enkei with some high performance tires. The springs are used, should i get the alignment right then or should i wait. the springs should already be settled right?? Also the car does need an alignment, pulls left and shakes over about 90mph.
________
California medical marijuana
________
Re: Should i
hahahaha
funny very funny, the sad thing is that it was washed just a couple days before i took the pictures. Gotta love winter in new england
________
LIVE SEX WEBSHOWS
________
LIVE SEX WEBSHOWS
Camber should also change....
see http://www.ingallseng.com/performance/camberchange.htm
I bought the "correction bolts", but haven't installed them just yet (or had an alignment for that matter).
After the spring installatin (H&R) the car drives straight, but indeed feels "darty" and seems to follow cracks in the road-both symptoms of excessive neg camber. Plus, my $250/ea Dunlops are showing a little bit of "feather-edging" on the innermost tread block (fronts only). Could be toed-out too.
Gotta get to the alignment shop....
Should i
What does everyone think of this item http://www.ingallseng.com/parts/3542.htm
It's only 15 dollars and if it will help at all i will get it, I'm planning on lowering 1.75 with intrax springs. Do i need one or two of those kits?? CYCLEMAX, your still alive, i haven't heard from you in a while. How you been. Even get around to using that AOL account i set up. Hope to see you and your shweet ride at the next meet.
________
LustyNata cam
________
LustyNata cam
Re: Should i
Re: Should i
Hey Steve:
Yeah, me and the Maxima are still alive. I just got back from the Carribbean and have been way busy lately so I've been laying low on the Maxima scene. Mine could use a good wash too. When's the next meet? I hope to make it.
Anyway, I got the bolts for like $11 ea. (they sell them individually) from BMP performance on the web (I think that's their name). Seemed like a really good source (polite and speedy delivery).
dch95 is correct in that they have a smaller shank than the originals, although I don't think it's half size. The bolt may be a higher grade than the original to retain the strength, but I'll have to check to be sure.
Hey dch95, do you remember what your specs were b4 and after the correction with the .5" bolts? I suspect the 1.3mm (.050") difference wouldn't be enough to correct for a typical 1.5" drop, which can be a whole degree or more. Is your car lowered or were you just looking to perfect the geometry on a stock setup?
Steve, I'd wait on the bolts for now. At least until you are ready to do the springs. I'll let you know what my numbers are once it's measured.
Well, I would recommend getting a lifetime alignment deal somewhere. You will need an alignment eventually (lowered suspension goes out of whack more quickly than normal), so why not get a lifetime deal somewhere. I paid $120 for a lifetime alignment at Firestone, and have gotten my money's worth already with three alignments in the past one and a half years.
Re: Hey Steve:
kingw323
20
10-21-2015 08:36 AM
laparka66
08-06-2015 09:36 AM
