How to hardwire Valentine radar detector? Any ideas?
Old Oct 19, 2003 | 02:40 PM
rdaneel's Avatar
Hi -
I did and search and have found some people that say they ran the normal phone wire under the dash and up the front windshield pillar. Others have tried to wire it to the sunroof. Is there an easy way to do this, especially one that explains how to hide the wire under the dash or interior panels?
Can I remove the pillar panel and run the wire under it?
Sorry - but I am a car electronics n00b, and could use some help!
Thanks,
RDaneel
Old Oct 19, 2003 | 03:52 PM
WaarrEagle's Avatar
Originally Posted by rdaneel
Hi -
Thanks,
RDaneel
I ran mine down to the cig lighter. I tried the sunroof first but because of the kind of switch it has it doesn't work for adding electronics. You can stuff the wire between the glass and the headliner across the top and then between the glass and a pillar down the side. Then you can tuck it between the body and the dash and the wire is completely invisible from any angle. If I did it again I would only run it to the fuse box as that would be much easier than running it to the cig lighter.
Old Oct 19, 2003 | 05:04 PM
rdaneel's Avatar
WaarrEagle - do you know where I can find out how to wire it to the fuse box? Can I just pick an empty lead and clip on the 12 volt connector that came with the V1? I might give that a try - sounds like the most elegant solution!
Thanks again for your help!
Old Oct 20, 2003 | 09:02 AM
rdaneel's Avatar
Anyone know which wire I can tap into in the fuse box?
Thanks!
Old Oct 20, 2003 | 11:08 AM
maximum810's Avatar
Tap the wire to the reading lights. It's easy to tap it, but a bit of a pain to run the wire inbetween the headliner and the roof of the car. Use one of the 3 screws holding the mirror to put ground, and it works fine. Just remember to turn off the radar itself when the car is off because those reading lights still get power with the car off.
Old Oct 20, 2003 | 11:48 AM
rdaneel's Avatar
Maximum - thanks for the suggestion - but I'm too afraid to do it that way - I know I'll forget to turn the detector off, and kill the battery. I'd really like to attach it to a switched source. I have the cable run to the fusebox, I just don't know which wire to tap. I guess I'll look for the 12V cig lighter wire and tap into it...
Old Oct 20, 2003 | 11:55 AM
SXN's Avatar
SXN
Its in the how to forum, a description for the V1 and the passport. check my sig or the top of the thread
Old Oct 20, 2003 | 12:40 PM
rdaneel's Avatar
Thanks for all your help! I found the wire was long enough to attach right to the area behind the 12V jack - and everything works!
This forum rocks!
Old Feb 21, 2004 | 11:15 AM
willis's Avatar
My heroine
sorry to dredge up a very old post... but
Can anybody verify the wire off the fuse box (white / blue) is the same as shown HERE? Just wonderin, thanks
wJ
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Justin Kroll
Oct 1, 2015 07:03 PM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
