CAI Questions...
Old Feb 18, 2001 | 07:00 PM
petemoe's Avatar
Just installed my new CAI and have a few questions for
you experts:
1) The filter is slightly pressed up against the
wheel well. I couldn't figure out how to arrange
the CAI so that it doesn't touch. Will this be
a problem? Only the bottom lip of the filter touches
the wheel well.
2) Was it hard for you guys to mount the fuse box back
into place? The bottom of the box hit the CAI. I
did get it in, but it is snug. Is this a problem?
3) Do you hear a slight "hissing" noise when you slowly
accelerate? Is this normal?
I'll post my findings in a few days or so. The short
of it, is that I love it and it brings a smile to my face.
Pete Mo.
95SE
Old Feb 19, 2001 | 06:28 AM
petemo95se's Avatar
Any help with these questions? eom
k
Old Feb 19, 2001 | 06:53 AM
Confused's Avatar
Permanent Maxima.org Resident
the hissing is normal as is the growl at wot.
as for the the filter being up against the wheel well, if your not getting vibration then no harm no foul. personally, i would try and rotate the tube the see if it pulls away from the fuse box and filter away from the side wall in the well... it sounds like a small twist might give you a different angle.
Old Feb 19, 2001 | 10:44 AM
ny96max's Avatar
1) as for the filter touching in the fender well, its normal! My cone touches at the bottom. It doesnt effect any performance at all! i think thats how all of the kits are, from what i have heard.
2) the hissing is also normal when accelerating. Even at an idle you probably hear the cone hissing. When i raised my idle the hissing got louder and now people think i have a super charger or somethin under the hood.
Old Feb 19, 2001 | 11:23 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
just another reassurance its normal...i am in the process of making a bracket to push my filter away from the wheelwell but i doubt i'll see any difference in performance...
god i love that sound
Old Feb 19, 2001 | 10:27 PM
DaEnigma's Avatar
Normal x3
I also love the hiss but mine sounds more like a whistle...
Old Feb 20, 2001 | 04:18 AM
Ramius83
As for the fitment of the fuse box, mine was a pain in the but to fit in mostly because I think I did not cut the hole at the exact position, since I had the drawing which shrunk. I seriously had to apply downward force with my body weight to make the holes line up right. All is well, it fits. The rubbing of the filter against the wheel well is ok, most everybody's does this. The hissing is pretty normal. You will notice the hissing noise go down as the filter gets dirtier. But dirtier is better since the oil on the K&N actually takes the dust and dirt and makes it "part" of the filter. Hope this helps
Old Feb 20, 2001 | 06:44 AM
breaux124's Avatar
Those are all the same issues that I had. I thought that the hissing sound was a bad seal somewhere, but it isn't. The filter just hisses at certain RPMs.
Maxima_Joe
Nov 25, 2015 08:19 AM
Sep 27, 2015 08:37 AM
A32goldylocks
Sep 16, 2015 01:33 PM
lowpost99
22
Sep 2, 2015 04:38 PM
BGTONIO1991
Aug 11, 2015 07:38 AM
