Weird GRINDING sound???
Old Oct 23, 2003 | 09:34 PM
JSClark's Avatar
Anyways, the past couple mornings (and choice afternoons going to lunch), when I try to start my car, I get some weird grinding noise... I'm thinking either its my starter, or *gulp* someone screwed up my last oil change. I'm trying not to drive my car as much as possible just in case, but I want to know what the hell this is. But then again, could it be because of the freezing weather, that I should pump the pedal at least once before starting or something?
Someone let me know, because I would rather not lose my max...
Old Oct 23, 2003 | 10:10 PM
chris j vurnis's Avatar
Here is a symptom I had which is common to starters on early 4th gens.
Basically on a cooler morning or afternoon, the starter was prone to making a very pronounced noise that could be described as a low-to-medium pitched metallic grinding sound that would last about around a couple seconds immediately once the car started.
Started happening to me around 80K miles. Replaced the starter, and the issue went away.
Old Oct 24, 2003 | 09:58 AM
JSClark's Avatar
Well, I'm hoping its just that. How much did a new starter cost you? and was it hard to replace, or did you have the dealership do it?
Old Oct 24, 2003 | 10:26 AM
Nismotic's Avatar
Always sunny in philly
starter is rather inexpensive (100-150?) but the install is very easy. search for it and u'll find the write up
Old Oct 24, 2003 | 11:01 AM
Capitone's Avatar
Or you could just regrease it for cheaper. Try this site for instructions!
http://www.motorvate.ca/mvp.php/516
Old Oct 24, 2003 | 01:51 PM
Kevlo911's Avatar
Kevlo for President
does it go VEHHHHHHHHHHHH if so follow the instructions on motorvate.ca
Mahmuth
Aug 16, 2024 08:23 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
