Dyno pre install Cattman Header & Catback insta
Very disappointed with my Dyno but willing to face reality. Are these number's normal for my Max ? All I have is UD Pulley upgrade and PR CAI,
also just installed all new coil packs and NGk copper spark plugs at .045 gap. I do have 18" Konig Holes.
Here it is :
1st. run 10/24/03 @ 3:44 PM 127.9 Max Power/Max Torque 157.7
2nd. run 10/24/03 @ 3:47 PM 124.2 Max Power/Max Torque 156.8
3rd. run 10/24/03 @ 4:01 PM 129.8 Max Power/max Torque 153.2
Sorry I don't have a scanner. I might take a picture with a digital
camera later on, but doe's that suck or what?
Now I'm ****ed!!!!!! can't wait for the install next week.
Forget the Nitrous, I'm going to Super Charge it 1st Quarter next year!
My follow up Dyno will come up after the Header & Catback install.
Hope everyone is happy now. Buy the way the guy's over at
Cartek Tuning in "Davie" are very cool. $75.00 for three runs. Next Saturday
is Dyno Day and they will have a special promo price for you guy's here
in South Florida "Go Marlins". Let me know what you guy's think.
Reality sometime's hurt's but it's worse not react on the outcomes. Wish me luck.
Here it is :
Here it is :
Reality sometime's hurt's but it's worse to take not react on the outcomes. Wish me luck.
Here it is :
I would check your knock sensor. It's really easy to check and is a common problem on the 4th gens. There are intructions on how to check it in the FAQ section.
Edit: I just saw you had 18 inch rims.....That will lower your numbers but I don't think they should lower them that much. BTW thanks for the before and after dynos of the headers.
Originally Posted by kevlo911
i think u have a DEAD KNOCK SENSOR, search for more info
stock auto's dish out 150 hp to the wheel and stock manual dish out 165+
Originally Posted by ivelweyz
.045 gap is too much, .039-.044 is our spec. The numbers are TERRIBLE. You're missing about 30hp/tq...
Acourding to some of the other threads here on the org .045 for the
NGK coppers are fine . Correct me if I'm wrong and I'll go back in there in the AM. These numbers however are freaking me out. The car did seem to have more pep after the coilpacks and plug change.
Originally Posted by SLC98Max
Those numbers are really low. You should be in the 150-160ish range for horsepower stock. I beleive torque should be 160-170ish depending on the dyno you use. Was it a dynojet? I got 180fwhp and 192fwTq with just a short ram intake, Ypipe and obx exhaust.
Originally Posted by 98maxgle
yeah those numbers seem low. u should perform a tune-up (clean TB, change PCV valve, new sparkies, check knock sensor, etc), you should notice a difference after u do this....And yeah MARLINS! all the way!
Here it is :
Here it is :
When I took out the original platinum's they where about .047!!
I thought the a/f ratio is NOT supposed to be flat...
I was like yeah right to myself but I'm going to have the knock sensor checked anyway.
Also, if you ask how to check the ECU codes, or change the knock sensor, you will be banned.
Originally Posted by mzmtg
You dont need to "have it checked." Check the ECU for the code yourself. If required, change it yourself. Dont pay other people to do this simple stuff.
The thing is that most of the time the knock sensor will not throw a code. You just need to have it checked. Mine never threw a code and when I had it changed because of the symptoms when I looked at it, it was cracked. Just have it checked or change it regardless of code or not.
