Brighter Tail Light Bulbs?
I have altezzas obviously, and When the lights are on the tials dont look so bright because of the red lense. Is there a Clear bulb like our factory ones that would be a lot brigther to switch the stock ones out with so the RED from the red reflector is real bright? Thanks
Nick
Nick
Nick
Nick
Originally Posted by Max4U
Maybe you can try LED bulbs. I would not recomend putting a higher wattage bulb unless you change out the fuse to a higher amp fuse. The fuse box is located under the driver side of the dash.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
