Burned out Connector for Headlight
Old Feb 20, 2001 | 09:20 PM
calvin418
Well, I've burned out my Headlight connector and needed to get a new one.
I picked one up, but does anyone know how to install it?
Is it hard? There are 3 wires that need to be attached..
do i need to disconnect the batter before i do anything?
Any advice would be great. Thanks.
Old Feb 20, 2001 | 09:47 PM
Kashoggio's Avatar
First of all why did your socket melt? Are you running the wrong bulbs with higher wattage? Now, yes you should disconnect the battery, unless you like a little bit of juice running through your body. Now just remove the old plug and solder in the new one. thats about it
Old Feb 20, 2001 | 09:52 PM
calvin418
Yeah.. the socket meleted b/c i had vision bulbs in.. i've had them for over 6 months ...
but don't most people put in these high wattage bulbs?
doesn't this happen quite often?
Old Feb 21, 2001 | 09:13 AM
1MAX2NV's Avatar
yep..happens quite often. Keep on replacing those sockets. Doesn't get rather annoying that you have to replace those all the time. LOL. Do a search on headlight harness upgrade. Get the APC harness.
Old Feb 21, 2001 | 08:40 PM
Kashoggio's Avatar
hehe now by what 1max2nv is trying to hint is that if you have more powerful bulbs in you also have to have right connections to handle the power. Thats where the Aps wire harness comes in, it costs $50 and your sockets wont melt, there for you can run your bulbs with no prob.
Old Feb 22, 2001 | 05:05 AM
Albertt's Avatar
1MAX2NV >>
Tony, you really worked up over this. Hehehe...it's funny to watch you rip on some of these kids when they talk about how they DON'T need an upgrade harness.
Old Feb 22, 2001 | 06:20 AM
NickStam's Avatar
I bet 95% of you who try and upgrade the damn lighting system can't even tell a difference. The only reason why I changed mine is so that they would look white vs. yellow. I can live with the inferiorer lighting that occurs as a result.
Old Feb 22, 2001 | 11:17 AM
Weasel's Avatar
Agreed with that... I just recently "upgraded" to BlueVisions and I really don't notice much of a difference. They are slightly better than the GE bulbs I had in there before, but nothing to write home about. The basic 9004 design is just too bad to get spectacular lighting out of. I'm considering adding pencil-beam pattern driving lights under the bumper in the lower grille, because I drive on a lot of dark highways and the stock lighting is just inadequate.
mclasser
22
Nov 12, 2020 01:58 PM
doctorpullit
Oct 28, 2019 10:58 PM
Noela
Sep 26, 2015 08:22 AM
