remote start and blower questions
Old Nov 6, 2003 | 04:13 PM
crak's Avatar
I have a 99 maxima and I just installed a crimestopper rs900 remote start system. Everything seems to be working correctly but the problem that I'm having is that when the car is in remote start mode the a/c-heater blower won't work. The radio and the lighter works but not the blower. I have looked all over the internet to find if there is a second accessory wire that I didn't know about but I haven't found any yet. I will appreciate any input in the matter. Thanks. If it makes it any easier you can e-mail me at Reycar69@hotmail.com
Old Nov 6, 2003 | 04:38 PM
Gotrice4's Avatar
dumb question, but is the a/c or the heater on when you leave the max?
Old Nov 6, 2003 | 05:19 PM
crak's Avatar
yes it's on.
Old Nov 7, 2003 | 01:19 PM
maximafever's Avatar
there is 2 starter wires on the 4th gen maxima both must be hooked up or you will take the chance of killing your starter. also listen to the difference of when you start the car with the starter and with the key.
Old Nov 7, 2003 | 01:22 PM
SilencingMachin's Avatar
Nevermind -- maximafever has the wiring info...
Old Nov 7, 2003 | 01:31 PM
most sites do not list the second starter wire but it is there and if you don't hook it up you will have problems. I know I was stranded by that mistake.
here is the wiring diagram from Bulldog Security
NISSAN MAXIMA 1999
WIRE COLORS LOCATION
12 VOLTS CONSTANT WHT/RED or WHT/VIO IGNITION SWITCH HARNESS
IGNITION 1 BLK/WHT or BLK/RED IGNITION SWITCH HARNESS
IGNITION 2 N/A IGNITION SWITCH HARNESS
IGNITION 3 N/A N/A
ACCESSORY/HEATER BLOWER 1 BLU or WHT/BLK IGN SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
STARTER BLK/YEL or BLK/WHT IGNITION SWITCH HARNESS
STARTER 2 RED/YEL or RED IGNITION SWITCH HARNESS
PARKING LIGHTS RED/GRN (+) STEERING COLUMN HARNESS
DOMELIGHT RED/WHT (-) DR KICK PANEL
PWR DOOR LOCK LT.GRN/RED (-) DR DOOR
PWR DOOR UNLOCK GRN/YEL (-) (TYPE B)
TRUNK RELEASE VIO/YEL (-) DR KICK PANEL
TACH SENSOR WHT/GRN AT ECM FRONT OF CONSOLE
BRAKE RED/GRN (+) SWITCH ABOVE BRAKE
HORN GRN/WHT (-) STEERING COLUMN
FACTORY DISARM GRN/YEL (-) N/A
N/A N/A
Old Nov 7, 2003 | 03:08 PM
crak's Avatar
I know about the second starter wire. I hooked it up with a relay and I tested it and is working fine. The car is still not starting while cold. When I turn it on with the key it starts in a couple of cranks but with the remote starter the car has to be warm and on top of that it'll take about 6 to 7 cranks to start. Also I can't get the blower to work. The radio works but the blower doesn't. I could have the car running with the key, engage the remote start, and as soon as I remove the key the blower stops working. Any info will be appreciated. Thanks
Old Nov 7, 2003 | 06:31 PM
njmaxseltd's Avatar
It's not wired in correctly. If you installed it, disconnect it and reinstall it again paying close attention to what your tapping into. Your missing an accessory power wire someplace.
ah2002
Mar 9, 2016 01:42 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
maximaham
Aug 7, 2015 01:11 PM
silver_i35
Aug 3, 2015 11:20 PM
