Bulbs burning out with brighter clearance light mod?
Hey guys...this is the second time this has happend to me. I did the brighter clearance light mod where u shave off the little stub on the lightbulb, and reverse it, making it bright all the time. I did this once with hyperwhite bulbs, and only ONE of my bulbs burned out. I did it again with other bulbs that i bought from procarparts.com for 20 bucks to match my hids, and they burned out again.
Luckily, i called them and they are sending me replacement ones. However, i dont want this happening to me again.
So im just wondering if anyone else is experiencing this, or am i doing something wrong?
i had mine around 1 year. at first i kept blowing fuses due to improper taping on the nuts. but after i fixed it with a new set of raybrigs hyperwhite, it hasn't failed me since then.
what brand of hyperwhite you have? IMO APC superwhite sux, polargs and raybrigs are better candidate.
might be your bulbs...
I just used stock bulbs that were in there (probably original 5 year old bulbs) and they've been in there 2 years, no problems... try using a stock wattage bulb and make sure you aren't touching the bulb w/ your hands (I know it's more of an issue w/ headlight bulbs but it can't hurt to try)
I agree
these are the ones im using that just recently burnt out...
http://www.procarparts.com/store-det...%2DXXXX%2DBU2X
it says its 12V 27W/8W ... is that the normal or higher ?
I took the corner lights out(ones right next to the headlight). They're not needed.I think they look goofy in the daytime b/c you just see an blue or orange blob behind the clear. And they never matched other lights perfectly at nite. Its just a cleaner look IMHO. Pop them out for a day and see if you like it...................
Originally Posted by kevlo911
i had my stock bulbs in there for well over 2 years
but one of my hyper whites(driverside) blew out in a day
I've had mine rewired for over 6 months and had those bulbs in my car for over a year and no problems w/ burning out. Try a diff bulb (brand)
the two bulbs that blew were two different brands. How did u "rewire" urs? All i do is just reverse the way the bulb goes in...
King_Ten_Ahead
Sep 30, 2015 04:27 PM
MikesChevelle
Aug 6, 2015 11:36 AM
