Help intake manifold.
Old Nov 21, 2003 | 12:30 AM
newborn1281's Avatar
I have 1997 maxima gle.
When car is cold after night, I start the car it idling normally but once you put it in to the drive or reverse it dies. I let it worm up a little put in to the drive again and then my engine does multiple cylinder misfires it won't work properly I floor it and RPMS do not go up its dying, in 3 blocks or so after engine gets worm its working perfectly fine again. So I took it to the shop they couldn't find anything but they think its an intake manifold air get in to the cylinders..
Here is the question Can i change it myself if yes how. May be it’s only a gasket how many is there? Does any one else had this problem.
Please help.
Old Nov 21, 2003 | 05:43 AM
1MAX2NV's Avatar
go to a different shop.
Please help.
Old Nov 21, 2003 | 06:01 AM
mzmtg's Avatar
Minister of Silly Walks
That does not sound like an intake manifold gasket problem.
Old Nov 21, 2003 | 06:27 AM
CullenJ76's Avatar
Old Nov 21, 2003 | 06:51 AM
Stephen Max's Avatar
I recently changed my intake manifold from MEVI to stock (temporarily). When I did I wasn't careful and a wad of shop towel got caught at the gasket surface, making a pretty substantial air leak at the intake gasket. The symptoms were almost exactly like what newborn described.
Old Nov 21, 2003 | 09:22 AM
1MAX2NV's Avatar
The gaskets aren't very expensive, but it's labor intensive. I would expect to take about 5 hours. There are numrous gaskets that you will need. So the off top of my head here is a list...maybe other people can think of more.
TB gasket
EGR gasket
Upper to lower gasket
lower to block gasket.
Old Nov 21, 2003 | 09:28 AM
TB gasket
EGR gasket
The difficult part is getting to the intake manifold bolts on the backside of the engine. You pretty much have to do it by feel. They require a 12mm wrench. I went out and bought one of those ratcheting closed end wrenches specifically for those bolts. Same with the EGR bolts, although they are easier to see and get to after you remove the IAC. For those a 12mm socket is needed.
Old Nov 22, 2003 | 11:14 PM
All this sounds to complicated i think i better off just go to the shop he he
aw11power
Oct 10, 2021 04:57 AM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
