Code 01 01 Camshaft position sensor HELP
Def, I burnt out my starter because it wouldnt start. Make sure you check both sensors though because I wasgettin the code for the sensor on the passenger side but it was the sensor on the drivers side that was no good.
DTC 0101 is caused by the Camshaft Position Sensor (Phase). This sensor is located on the engine front cover facing the camshaft sprocket. It detects the cylinder number signal. The Engine Control Module uses this signal to control spark plug firing order and also to sequence the fuel injectors correctly. If the CPS is bad the ECM will fire the plugs at the wrong time, or not fire them at all. This would account for a no-fire symptom.
Originally Posted by worm
i had the same problem with the camshaft sensor, car wouldnt start and all that crap, replaced it and all my problems are gone.
until i got this stupid cylinder misfire. POS.
Got a trouble code? My car doesn't start but no codes.
ballerchris510
Sep 23, 2015 08:46 PM
