Erasers in motor mounts!
Old Sep 28, 2004 | 09:13 PM
  #41
nadir_s's Avatar
vicodin ... gift of life
holy **** haha i gotta try this..... gonna go buy a pack of my fav erasers... magic rub!
Old Sep 28, 2004 | 09:15 PM
  #42
nadir_s's Avatar
btw, can you get a pic? The one you psoted is a dead.
So what are our best substitute to erasers... any paste or something we can just squeeze in there and hope for it to harden ?
edit:
i found this link:
http://features.evolutionm.net/article/rrmcorner/14/2
they use 3M windo weld urethane.. that work?
Old Sep 28, 2004 | 09:55 PM
  #43
goodhead's Avatar
hey if you are removing the mounts can i remove them 1 at a time w/o supportign the engine?
so like take one off, fill w/ window stuff, wait dry 24 hr, put back in, do next one??
also theres 4 mounts right? anyone you cant take off without supporting engine/ transmission?
how do you check if your mounts are still good?
also if your mounts are bad can you still do this?
Old Sep 28, 2004 | 10:59 PM
  #44
joaquink's Avatar
¿Hablas Español?
edit:
i found this link:
Old Sep 29, 2004 | 12:00 AM
  #45
v6maximus's Avatar
Well be god damned! I'm laughing my freakin' a$$ off here while reading this... Pink erasers as a performance upgrade!
Old Sep 29, 2004 | 07:45 AM
  #46
michaelnyden's Avatar
just wondering how to put them in there...cause I can't seem to squeeze any in...I must be shoving them in wrong...cause I can't even get one in....need pics with like an arrow or something of which way to shove them in
I did buy a large can of polyurethane at my local hardware store...maybe I should just do this the right way and fill it with it off the car...
Old Sep 29, 2004 | 07:47 AM
  #47
phenryiv1's Avatar
Mod her. Ate her.
FYI, guys- this thread was almost a year old, so you might not get responses from the people on page 1.
Old Sep 29, 2004 | 08:20 AM
  #48
PoePoe2797's Avatar
WOW, I can't believe someone found this. Make sure you lube the erasers or else they wont go in. They only fit 2 ways into the hole in the mount...directly in and sideways. For the front/rear, do ssideways and the 2 on the side do directly in. You have to kinda angle the erasers to get them in the openings, and there is a rubber flap in the side of the mounts that you have to hold back to see the hole in the mount.
Old Sep 29, 2004 | 09:25 AM
  #49
Chunger's Avatar
My other car is a Hybrid
I don't know how durable the erasers are after several heat cycles...
I originally used 2 or 3 pieces of fuel hose and that helped.
I now have 2 new mounts with 3M window weld filled in there. I dried/cured it in an oven for 24 hours before installing.
And no, you have to remove the engine support beam and support the engine/trans to remove the 2 mounts below (front and rear).
Old Sep 29, 2004 | 03:53 PM
  #50
nadir_s's Avatar
how's yours holding up?
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
