HELP!!! Car won't stay warm!!!
Old Nov 25, 2003 | 06:22 AM
USRacer900's Avatar
So it's ball freezing cold this morning. Go out and let car warm up for probably 10 minutes. Temp gauge is maybe half way up when I get back in. Turn on heat full blast and drive to work. Temp gauge goes down all the way to the cold mark!! Starts blowing luke warm air. I've never seen a car do this, hopefully it's only a thermostat, anybody else have a similar incident or ideas??
Thank you.
Old Nov 25, 2003 | 06:57 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by USRacer900
thermostat Thank you.
maxceleration's Avatar
have you changed youtr oil?
Old Nov 25, 2003 | 09:41 AM
USRacer900's Avatar
Mmmm, just curious, how would changing the oil affect the temp? Maybe I'm missing something.....
Old Nov 25, 2003 | 09:42 AM
USRacer900's Avatar
Also, if it's indeed the thermostat, would you guys recommend OEM over say autozone/Advance brands? Is the quality any different?
Thank you again.
Old Nov 25, 2003 | 10:15 AM
well, my friend didn't change his oil in his car on the regular scheduled time, so his engine wasn't running normal. The A/C was not cold and the heat was not hot. The car would not warm up correctly also. HIs temp guage was either low on C or more than middle. Then a few months later, his engine died on him.
Old Nov 25, 2003 | 10:43 AM
mzmtg's Avatar
Minister of Silly Walks
Your thermostat is stuck open. I was having the same problems as you. I replaced my stat with an autozone brand part this weekend and it's all toasty now.
Old Nov 25, 2003 | 11:03 AM
USRacer900's Avatar
Thanks! I'll give a new thermostat a try.
Old Nov 25, 2003 | 11:49 AM
LudeAEM's Avatar
Def open thermostat. lucky for you it didn't stayed closed, then that would lead to overheating.
Old Nov 25, 2003 | 12:33 PM
USRacer900's Avatar
Next question: Where's the thermostat located at? Looks to me like it might be on the left side of the engine (standing in front of car) above the alternator??
Thanks again!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 25, 2003 | 12:36 PM
Jeff92se's Avatar
I'm needing a caw
http://www.cybrrpartspro.com/Chilton...961CH03_5.html
Put this link into your favorites and refer to it often!
Old Nov 25, 2003 | 12:58 PM
USRacer900's Avatar
Thanks man, I take it I have a VQ30DE engine, right? (96'max)
Old Nov 25, 2003 | 01:12 PM
Jatan's Avatar
Yep
So when the thermostat is stuck open, the car would cool down quickly? After I drive and turn off the car, the car gets cold quickly. The heater air is not that hot either
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
beboski
Aug 16, 2015 05:23 PM
BobMax
Aug 15, 2015 12:35 PM
