what is the stock wattage on our gauges? NEED HELP ASAP!!
Old Nov 28, 2003 | 11:10 AM
silvermax2k2's Avatar
i just took my gauge cluster off, and under took a project. my goal was to fit 194 lights into my 99 maxima. so i dremeled, and soildered, and i was happy. i go to plug them back in, and only the digital OD lights up, and nothing else. i turn on my lights, and none of the lights work, and i hear a faint humming noise. so i am guessing i have the wrong wattage? can anyone help me? i can't drive!!!!
thanks
Chris
Old Nov 28, 2003 | 11:20 AM
JeremyMarkham's Avatar
I think there was a long thread on this...cant search so I really cant help much.
Old Nov 28, 2003 | 11:24 AM
Kevlo911's Avatar
Kevlo for President
did u tyr messing hte dimmer switch? did u plug in hte dimmer switch?
Old Nov 28, 2003 | 12:01 PM
MIXXMAX's Avatar
Oh, Oh. You may have ruined the circuit by installing the 194 bulbs in the cluster. Nissan changed the bulb size and wattages in their clusters from '99 and on (possibly '98 also). The bulb for your particular year is a smaller size and different wattage. Adding a higher wattage bulb in the circuit board will only burn and possibly fry the circiutry. If I were you, I would install the original bulbs back in the cluster and see if everything works as normal. This topic has been discussed so so many times. There is NO possible way of making the digital odometer clusters brighter by replacing higher wattage bulbs, other than the bulbs it is designed for.
Old Nov 28, 2003 | 12:17 PM
oh, i am stupid. right after i made this thread i took a rife to autozone to find out stock wattage. on the ride there, i turned on my headlights, and my bose radio turned off. (the radio worked, but it did not light up.) so i thought for a while, and then it hit me, and then i hit myself! lol, i forgot to plug in the dimmer! ahh, i suck. but thank you for your help guys.
am i really going to burn out my circuits??? now you have me thinking about that...
chris
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
