Emblem residue
Old Nov 30, 2003 | 01:45 PM
Titan14's Avatar
Emblem residue
after shaving my emblems i have been having some trouble with the residue left behind.......so far i have been using bug and tar remover w/ a side of elbow grease but damn its taking forever..........any recommendations?
Old Nov 30, 2003 | 04:21 PM
darrick's Avatar
Dallas Nissan Enthusiast
goop of or goo gone and the wash and wax and you a$$ will look as good as this
Old Nov 30, 2003 | 04:23 PM
geo1317's Avatar
heat it up with a hair dryer, it should make it easier to take off
Old Nov 30, 2003 | 06:25 PM
Jatan's Avatar
I have the same problem Going to try some 3M Adhesive Remover in a few days
Old Nov 30, 2003 | 07:34 PM
MaximaEvolution's Avatar
Rub the residue with gasoline. Thejn rub as much off as you can using your fingers. Afterwards, get some scratch remover to remove the "Outline" of the emblems from all the years of road debris and dirt. Then wash it, wax it, stand back and smile.
Old Nov 30, 2003 | 07:35 PM
SXN's Avatar
SXN
that is the worse idea i have ever heard... dont use gasoline on residue that is stuck to your car PAINT
Old Nov 30, 2003 | 07:37 PM
I used it and it does not take off paint. Nor does it affect it in any way.
Old Nov 30, 2003 | 07:43 PM
SXN's Avatar
SXN
gasoline is bad for your clear coat. its not a smart idea to get it on your paint period.
Old Nov 30, 2003 | 07:58 PM
its not sitting there for days on end if you wipe it on then wipe it off followed by washing and waxing it won't do anything
Old Nov 30, 2003 | 08:03 PM
SXN's Avatar
SXN
still a bad idea, period. Plenty of things like gas would take the residue off (lighter fluid, paint thinner, etc) but i would never put them on my car paint.
Old Nov 30, 2003 | 08:05 PM
Then what do you do when you pull the gas pump out and it drips a little gasoline on your car?
Old Nov 30, 2003 | 08:06 PM
Its not really a big deal. I can understand if it's poured all over the car and it just sits there. But not if it's a small amount and it's only on there for 5 minutes tops.
Old Nov 30, 2003 | 08:12 PM
SXN's Avatar
SXN
gas stations have paper towels at every pump. get some water from the squeege (sp?) thing, wipe it off.
Old Nov 30, 2003 | 08:55 PM
exactly, wiping it off with water is even worse than washing with soap, then waxing. Just trying to prove a point. Gasoline is not that bad for it if it's on there for a short period of time.
Old Nov 30, 2003 | 09:13 PM
Oblongshapes's Avatar
rubbing mine with goo gone and bug and tar remover on a hot day made it all clean.
Old Nov 30, 2003 | 09:15 PM
geo1317's Avatar
hot day = hair dryer
Old Nov 30, 2003 | 09:16 PM
SXN's Avatar
SXN
wrong. wiping a drop of gas off my car with soapy water is better than using a rag to rub gas ONTO my car. i still wouldnt do it or recomend it.
Old Nov 30, 2003 | 10:39 PM
Titan14's Avatar
thanks for the responses guys, will try tom. and let u know
Old Dec 1, 2003 | 12:18 AM
NISMOMAXMAN's Avatar
I did mine this past weekend, I took off my gold emblems and swapped with silver, I used goo gone, spray it a couple of times, and let it soak. Then just work it off with your fingernail (*gross but it works). Trust me, hey does anyone know what I should use to put back the M-A-X-I-M-A in silver, I was thinking double sided tape, traced out and stuck to the letters, and place them back in order? Any advice?
Old Dec 1, 2003 | 07:58 AM
techie's Avatar
Where did you get the letters and which ones did you get? 95-96 used seperate letters 97-99 was one piece, all the letter are connected. The dealership sells the MAXIMA letters for the back for around $16 and it comes on a strip, lined up for the 95-96. Just peal the paper off the sticky side, apply, and pull the top strip off.
REDinLV
Aug 15, 2024 12:30 AM
adamgalazka
Feb 5, 2023 08:24 AM
05RLS2
Nov 7, 2016 05:52 PM
jc53
Oct 6, 2015 06:00 AM
MaximaRaj
27
Oct 2, 2015 07:31 AM
