Throttle position sensor?
Old Dec 1, 2003 | 08:20 AM
95MaxSE's Avatar
Hi guys,
For some reasons I can not search this bulletin board. It keeps telling me that I don't have access.
My 95 Max GXE (100,000 miles) reports 3 problems:
1) Throttle position sensor: Where is this sensor located? How much does it cost, and how easy/hard is it to replace?
2) Knock sensor: Again, where is it? Cost, and installation?
3) Rear Oxygen sensor: Same questions as above.
Thanks in advance for sharing your experience.
Sam
Old Dec 1, 2003 | 09:51 AM
twiggy144's Avatar
Someone really ought to re-enable the search feature!
Old Dec 1, 2003 | 12:17 PM
Stephen Max's Avatar
Originally Posted by 95MaxSE
Hi guys,
Sam
1. The TPS is on the firewall side of the throttle body. It is black and has two harness connectors plugged into it. Don't know how much it costs. It is very easy to replace.
2. The KS is on top of the lower intake manifold. It costs about $130-160. It is difficult to replace because of limited accessibility, but it is doable if you have small hands.
3. The rear oxygen sensor is located at, or just behind, the main catalytic converter. Cost is about $85-130. Easy to replace.
Get a Haynes manual. It will answer a lot of questions you might have.
Old Dec 1, 2003 | 01:17 PM
CullenJ76's Avatar
9 out of ten times when you replace your knock sensor, the rear heated oxygen sensor code will dissapear.
Also, your TPS is probably just out of adjustment.
Old Dec 1, 2003 | 01:45 PM
95MaxSE's Avatar
Thanks CullenJ76 for your advice. I will try the KS first.
How difficult is it to adjust the TPS?
Sam
Old Dec 1, 2003 | 02:28 PM
Kevlo911's Avatar
Kevlo for President
most of this can be found in hte 4th gen how to's; link in my sig
Old Dec 1, 2003 | 03:47 PM
CullenJ76's Avatar
yes, Excellent writej-up on adjusting the TPS!
I always forget about the how-to's
Old Dec 1, 2003 | 04:16 PM
95MaxSE's Avatar
Thank you, kevlo911 for the references.
Sam
mvm062
Nov 30, 2020 09:00 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
