Factory Alarm Problems, Need Serious Help.
Old Dec 11, 2003 | 07:45 PM
s0ber's Avatar
Well it seems like my factory alarm is activated, the starters not getting any power, we tested it and it gets power at the fusebox, cant check any futher than that.. We ran a wire from a powersource to the starter and it cranks but it doesn't turn over.. The injectors are not getting any power either...
Seems that the factory alarm has shut off power to the starter/ecu.. The security light constantly blinks, doesn't change patterns at all... I just got my ignition replaced and that probably triggered it...
I would like to know how to disarm the factory system? I tried putting the key in the door and turning it.. Dont work.. Also I dont have a trunk key anymore, I removed the cylinder from the trunk and filled it in... Any help would be greatly appreciated.. Thanks
Old Dec 11, 2003 | 07:57 PM
myke321's Avatar
Do you have the Silencer kill swich installed?? (look under your stearing collum)
Old Dec 11, 2003 | 08:03 PM
s0ber's Avatar
Theres no killswitch under my steering wheel
Old Dec 11, 2003 | 09:38 PM
darrick's Avatar
Dallas Nissan Enthusiast
sorry to say this bro but it sounds like your computer is shot, just went through this cost was 900 bucks at dealer but it was covered under warranty.
Old Dec 12, 2003 | 07:59 AM
s0ber's Avatar
Would the computer being shot cause the starter not to crank?!
Old Dec 12, 2003 | 10:40 AM
s0ber's Avatar
Old Dec 12, 2003 | 11:09 AM
Neef's Avatar
my max did the same thing.. I had to "bang" on my starter for it to work. I was getting power to the ignition and the starter but it wouldnt crank. Hit it a few times and hasnt stopped working ever since. Try that thanks
Old Dec 12, 2003 | 02:46 PM
s0ber's Avatar
No No, the starter DOESN'T get power.. thats my problem, I ran a wire to the starter and it cranked fine but it just doesn't turn over... no fuel... Somethings cutting the power to the starter and fuel
Old Dec 12, 2003 | 03:16 PM
Kevlo911's Avatar
Kevlo for President
bad ignition switch?,
http://forums.maxima.org/showthread....gnition+switch
happen to me and many other 95-97's( early 97's)
Old Dec 12, 2003 | 03:19 PM
s0ber's Avatar
I dont believe its that, when I turn the key all the relays click and the starter wire gets power up to the fuse box.. I could not test any futher than that as it went into the firewall.
Mar 12, 2020 12:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
