heater no blowing hot air
Old Dec 21, 2003 | 09:07 AM
madmega's Avatar
hey guys, i just purchased a 96 se bout a month ago. im here in ny and its freezing. the heater worked fine for the first month, now when i turn the heat up to 85 and all 4 blowers going, it doesnt blow hot air, its barely warm, its actually colder on full blast than if i just had the vents open and no fans on. anyone know what to do, could it be my heat core or something?? its freezing and i know its only gonna get worse
Old Dec 21, 2003 | 03:02 PM
maxcooldc's Avatar
I Am Sure That Must Suck, Anyways I Had The Same Problem Two Days Ago And Posted It Here On The Forum And Got An Answer That Solved My Problem
The Answer Is The Coolant Level In Your Car Check That If Its Low Then That Was Your Problem If Not Then I Really Dont Know What It Could Be The Problem
Old Dec 21, 2003 | 03:41 PM
ManualMaxima's Avatar
5th Gen till she dies!
check the heater core...d o you have any sort of fluid in the floor board of your car? It might be a heater core.....
Old Dec 21, 2003 | 03:42 PM
twiggy144's Avatar
Why Do You Capitalize Each Word?
Old Dec 21, 2003 | 05:35 PM
sharkulator's Avatar
I attempted to flush and change my thermostat and for my trouble got an air pocket in my cooling system. This also caused a no heat from my heater. Have you tried to flush and fill? That thermostat on a 99 is a pain in the **** to get off, in fact I think only a shop can get to it.
Old Dec 21, 2003 | 05:37 PM
vsamoylov
i have a heater core for sale if you need it.
Old Dec 21, 2003 | 08:38 PM
madmega's Avatar
ok where is the heater core, and how would i check it to make sure its in working order... i will check my coolant level first thing in the morning
Old Dec 21, 2003 | 09:00 PM
Frank Fontaine's Avatar
I don't think the guy should apply at Stanford either he said if the coolant isn't low he doesn't know what else could be causing the problem. Can we at least require an IQ of 85 to join the forum?
Old Dec 21, 2003 | 09:45 PM
vsamoylov
heater core is in the heater itself which is located under the right side of the dash. remove the glovebox and you should see it. if you need a pic of how to remove it, pm me cause i have the nissan maxima service manual from nissan.
Old Dec 22, 2003 | 05:24 AM
mzmtg's Avatar
Minister of Silly Walks
No it isn't.
It's a 20 minute job to swap the thermostat. Including draining and filling the coolant. Read the FAQ.
Old Dec 22, 2003 | 06:01 AM
95bluse's Avatar
Low coolant most likely. Happened to me this year also. Turned out to be a leaky water pump seal letting it all drain out.
Old Dec 22, 2003 | 06:34 AM
ABK's Avatar
ABK
What's your temperature gauge reading?
Old Dec 22, 2003 | 06:42 PM
Originally Posted by mzmtg
No it isn't.
Well it was for me, I didnt have a ratchet that would fit in there, it was just a crap experience for me. I got frustrated with the whole thermostat right next to the friggin frame set up. I took it to a mechanic who stated he lifted the engin up a few inches to get at it.
Old Dec 23, 2003 | 06:33 AM
jayanth's Avatar
the easiest thing to do is to change your coolant temp sensor.Check your gauge it should be 1/2 up the range within the first 5 mins after you start your car in the morning.Its a $26 part at auto zone or Adv auto parts.Change this part, check the coolant level and if there are no other problems like your core etc you Will get hot air.Trust me i have suffered for months last winter waiting for that thing to blow some hot air!
merry christmas,
Jay
Old Dec 23, 2003 | 06:38 AM
mzmtg's Avatar
merry christmas,
Jay
The coolant temp sensor has no effect on the temp of the coolant...
Only the thermostat does.
Anyway, you just need a 10mm socket on a ratchet with a universal joint to get the thermostat out. You don't need to lift the engine or any crazy stuff like that.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
Justin Kroll
Oct 1, 2015 07:03 PM
