Budeget b-pipe sucks
Old Dec 22, 2003 | 12:00 PM
maxspeed96CT's Avatar
The original VQ...
I have had my budget b-pipe for a few weeks now and its realy starting to ptick me off. It sounds great but hanges really low, i have about 3 inches of ground clearance. I have tryed everything from rigging hangers to all kinds of stuff. I took it to my local muffler shop and they siad to only way to fix it from hanging so low is to bend it by the axel, i cant real explain it but all i have to say is budget isn't top presise with thier bending measurments. If any one is thinking of getting a b-pipe , learn form my misstake and pay more and don't get budget. For now i have some getto *** hanger next to the gas tank that didnt help much and is about to break.
Old Dec 22, 2003 | 12:40 PM
NookieMax's Avatar
metal coat hangers
Old Dec 22, 2003 | 01:35 PM
davey6693's Avatar
You must be unlucky. I'm very pleased with my budget B-pipe. Installed with the minimum of fuss and haven't had a moment's trouble with it since day one.
Old Dec 22, 2003 | 01:36 PM
Kehops's Avatar
How is the Budget B-pipe any different than any other B-pipes out there? All B-pipes are extemely similar in design and all bolt on the same way. Think about it, I doubt this a Budget issue.
Old Dec 22, 2003 | 01:38 PM
Chron!cRAGE's Avatar
I love my budget bpipe. It hangs higher than the stock pipe and I never scrape with it.
Old Dec 22, 2003 | 01:41 PM
The original VQ...
well i know 2 peaople with warpspeed and their b-pipes are fine.
No not all b-pipes are the same, they are all diffrent diameters and have slitly diffrent bends. Maybe it is just my b-pipe that they messed up the bends on but that is no excuse.
They do all bolt on the same way and the hanger that is next to the suport beem thing is welded in the wrong spot , The pipe just looks like it was made half-a$$.
Old Dec 22, 2003 | 01:46 PM
myke321's Avatar
how come in you cardomain website, you say that you have a warpspeed y-pipe?
Old Dec 22, 2003 | 01:55 PM
The original VQ...
because i do have a warpspeed y-pipe and i love it.
Then when it came to buying a b-pipe i went for what ever was cheaper and i went with budget. I wish i went with warpspeed on the b-pipe.
Old Dec 22, 2003 | 02:32 PM
KWheelzSB's Avatar
Question. . .
Did you try to resolve this problem directly with Budget Exhaust before posting that their product SUCKS in a public forum?
I have one of their Y-pipes and although I haven't yet installed it, the previous owner installed it on his '97 and was very happy with it.
It is possible they screwed up the bends on YOUR pipe. I'm sure if you make an effort to contact Budget, they would be willing to work with you at resolving the problem.
Old Dec 22, 2003 | 02:36 PM
myke321's Avatar
O I C!
Old Dec 22, 2003 | 02:48 PM
The original VQ...
well i tryed but its to late now, ive had it on my car for about a month now, and everyweek iv ben tryin to figure out how to keep it from hanging so low . I guess im just going to have to pay some money and go to a muffler shop and have them weld me new hangers and and maybe try to rebend somethings.
Old Dec 22, 2003 | 07:14 PM
KWheelzSB's Avatar
Gotta do what ya gotta do, I guess.
Make sure if you have a muffler shop bend the pipe that they have a mandrel bender. Most don't. They normally use crimp-style benders, which will restrict exhaust flow & defeat the purpose of having a mandrel bent y-pipe on your car.
Good luck.
Old Dec 22, 2003 | 09:49 PM
gabex's Avatar
DEFECT.
Well, I dont know. All I can say is that my Budget B Pipe (w/ Magnaflow Resonator) is great. It does not hang low like yours. Did you install it yourself?
Old Dec 22, 2003 | 09:51 PM
The original VQ...
Originally Posted by gabex
DEFECT.
yes i did install it myself and many people have tried to help me fix it.
Old Dec 22, 2003 | 11:01 PM
TofuShop's Avatar
mayb its on upside-down
Old Dec 22, 2003 | 11:14 PM
BadKarma99-4spd's Avatar
call budget, any company worth anything will stand by their products and do what they can to make you happy. simply ask them to send you a new b-pipe after explaining your problem and then you can send your old b back later.
i did this with maxtuning's vb and they were more than happy to immediatly send me a new vb overnight
nobody's perfect and i know how it feels to be the only one having problems with a mod that works for everyone else.
good luck
Old Dec 23, 2003 | 12:16 AM
GreaseMonkeY's Avatar
I love my budget B pipe.
Old Dec 23, 2003 | 06:11 AM
The original VQ...
good luck
ill try it and i hope they help me. thanx
Old Dec 23, 2003 | 07:07 AM
97blackSE's Avatar
use hose clamps, It will raise the exhaust up...
wrap the hose clamp around the rubber hangars and tighten till it pulls the exhaust up
Old Dec 23, 2003 | 07:54 AM
Dave B's Avatar
Not DAVEB the parts guy
Sounds to me like the flange that bolts to the cat is rotated a bit too much and causing the rest of the pipe to rotate down. Do you have a stock cat or aftermarket. If you have an after market cat with freely rotating flanges, you can loosen the bolts, rotate the cat flange, and the B-pipe shoud rotate up. Keep in mind that when you do this, other clearances will be off and may bang portions of the body.
I've owned two B-pipe over the years, Stillen and Courtesy, and they both fit like crap. They both hung too low, they both it the trailing arms under big bumps, they both needed constant adjustment, etc. I don't understand why it's so hard to make a good fitting b-pipe.
Dave
Old Dec 23, 2003 | 05:04 PM
KWheelzSB's Avatar
Direct their attention to this thread & tell them they can give it (& you) a happy ending. Best advertising around! They'd be doing themselves a favor.
EDIT:
(Actually, better skip that - I just remembered what you titled this thing).
Old Dec 23, 2003 | 05:34 PM
Vyrus's Avatar
Hey maxspeed96CT, I have the exact same problems as you and feel the exact same way. The only way to fix it is bending, and nobody wants to do that to a pipe they paid extra for just so it was mandrel-bent. My muffler was also way of and I had to get custom hangars, be glad you don't have that! Anyways it is a very poorly constructed pipe, if I had known better I would have paid more for Stillen or WSP. My pipe also bangs against the exhaust shields and the flanges do not seal tight.
To all you people who say to call Budget and send it back, I am SURE they would make an exchange. But you have to remember how much work is involved in taking the pipe of, packing the old one and shipping it, reinstalled the new pipe etc. It is A LOT of work which most people aren't willing to do.
On the other hand, my Budget y-pipe is very well build and bolted right on. The only problem I noticed is that now it is getting some spots in the paint from I guess a coolant drip or such. The paint is not very good, but no rust yet (fingers crossed).
-Cyrus
Maxima Pride '07
Sep 12, 2015 07:29 AM
maximusrising
Sep 4, 2015 06:31 PM
paulpearl
Sep 2, 2015 07:50 AM
MikesChevelle
Aug 6, 2015 11:36 AM
