Cruise Re-wire... now NO CRUISE! Help!
Old Dec 23, 2003 | 11:05 PM
Stringztoo's Avatar
I followed the directions but my ACSD relay did not look like the one in the FAQ's write up. I used a 14 gauge wire with two male clips and the hardware was right but the application must have been wrong. I attatched the wires in slots 1 and 6, then 1 and 3, then 1 and 2, and 6 and 7 but not once did my cruise light stay on, and now I since I replaced the fuse and relay back to its original configuration, I have no cruise control! Here's a diagram of the relay's layout. What do I do? I have a 99 SE-L.
Old Dec 23, 2003 | 11:49 PM
SXN's Avatar
SXN
use these two links, it is terminal 3 and 5
http://www.vqpower.com/v2/modules.ph...showpage&pid=4
http://forums.maxima.org/showthread.php?threadid=37016
Old Dec 24, 2003 | 04:55 AM
Stringztoo's Avatar
...but isn't it weird that my cruise no longer works even with the original relay in the socket?
Old Dec 24, 2003 | 05:34 AM
Kevlo911's Avatar
Kevlo for President
check the fuses, i think you shorted something by useing the WRONG directions.
Old Dec 24, 2003 | 11:03 AM
Stringztoo's Avatar
Goodie! Now I have a new problem... The sunroof doesn't open or close. Having cruise on all the time doesn't seem like it's worth this heartache. What the hell is wrong!?!
Old Dec 24, 2003 | 11:11 AM
Kevlo911's Avatar
Kevlo for President
once more, check the fuses
Old Dec 24, 2003 | 07:30 PM
Stringztoo's Avatar
Does one fuse control the windows, cruise control, and the sunroof? This is getting a little outta hand!
Old Dec 26, 2003 | 05:10 AM
Stringztoo's Avatar
bump 123456
Old Dec 26, 2003 | 07:50 AM
nupe500's Avatar
Jedi Knight
no buddy...first check the window fuses...then the cruise fuses...now...does your horn work? The reason I ask is that the Cruise and the horn are on the same circuit...
Old Dec 26, 2003 | 11:26 PM
Stringztoo's Avatar
The horn works fine. These are the things not working since I tried the cruise re-wire:
1. Cruise control
2. All 4 windows
3. Rear window defroster
These all can't be on the same circuit, can they?
Old Dec 26, 2003 | 11:27 PM
Stringztoo's Avatar
The horn works fine. These are the things that have stopped working since I tried the cruise re-wire:
1. Cruise control
2. All 4 windows
SXN's Avatar
SXN
check your fuses...all of them. by hooking up random relays like an idiot caused you most likely to short something out. to keep you from mortally wounding your car, you have fuses in place at major important electrical connections. that would explain why the electrical blunder caused further problems with other parts of the car. CHECK THEM
Old Dec 26, 2003 | 11:59 PM
SXN's Avatar
SXN
no, but they can be on individual sepperate circuits. you mis-hooked the jumpers to SEVERAL relays, why dont you believe us that you could have blown more than one fuse? check them
Old Dec 27, 2003 | 06:55 AM
Kevlo911's Avatar
Kevlo for President
WHY CAN"T YOU just do what we say instead of asking Q's?
Old Dec 27, 2003 | 10:08 AM
Stringztoo's Avatar
Arrggghh... can you believe that all my problems came from this little bugger? Who'd have thought the cruise, windows, sunroof and rear defroster would all be powered by this 7.5v fuse??? And it's only labled "Electronic Parts"! Everything in the car is an electronic part!
Anyway, 3&5 and 6&7 worked and I am one happy fool. I'd llike to thank those who were patient enough and took the time to help me out. Now I have to figure what's up with my foglights...
Old Dec 27, 2003 | 10:34 PM
SXN's Avatar
SXN
HOLY CHRIST! IT WAS A FUSE LIKE WE ALLLLL SAID.... i hate you. just do what we say next time.
Old Dec 27, 2003 | 11:26 PM
Stringztoo's Avatar
But you see... the fuse that was blown wasn't any of the fuses that were labled for the sunroof, cruise, windows, or defroster. Each of those components has a fuse for it, and all were fine. Who'd have thought to pull the "Electronic Parts" fuse?
Old Dec 28, 2003 | 12:00 AM
SXN's Avatar
SXN
they were all electronic parts werent they? i said check the fuses, if you checked them, you would have seen one of them was blown
Old Dec 28, 2003 | 05:44 AM
Kevlo911's Avatar
Kevlo for President
just like i said all along check the fuseS. PLURAL. Well it doesn;t matter now since the car is working
Old Dec 28, 2003 | 11:29 PM
SXN's Avatar
SXN
when will they ever learn kevlo?
Old Dec 29, 2003 | 05:12 AM
Stringztoo's Avatar
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
schmellyfart
Sep 25, 2015 04:47 PM
jchronis2552
Sep 21, 2015 05:52 AM
Maximeltman
Aug 31, 2015 01:01 PM
