squeeky noise from H&Rs
Old Sep 20, 2000 | 12:25 AM
Ed F's Avatar
heya everyone...i just got the H&R/tokico combo installed about 3 weeks ago..and i hear squeeks sometimes when i hit a bump..and also when i'm making a sharp right turn it makes a grinding noise which sounds like the wheel hitting the wheelwell...is this suppose to happen cuz i thought it might do that since its brand new...but its been about 3 weeks now...any feedback would be good...thanx =)
Ed
Old Sep 20, 2000 | 12:46 AM
Eric L.'s Avatar
When I first had my H&R/Tokicos installed, they made a creaking/groaning noise when I turned the steering wheel. It turned out that the upper strut mount on the right front was scraping against a bolt that was sticking out from the body of the car under the hood. It's two bolts which stick through the metal into the wheel well, near the windshield wiper motor.
It was obvious that was the problem because when I removed the front right strut, there were scrape marks on the upper strut mount. I fixed the problem by installing a few washers to give the bolt more clearance. After that, no problems at all.
Someone not familiar with this problem might think it's an improperly seated spring (or one that is installed upside down). You can check that by seeing whether the spring turns with the strut when you the wheel, and the lettering on the spring ("H&R") should be right side up.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
