Problem with Cooling System ?? PLEASE ??
Old Jan 7, 2004 | 09:40 PM
matty's Avatar
Alright on my buddies 95' SE 130K miles on it 5spd
He was having a bad leak for a while in the cooling system so he brought the car to get a water pump put in at a NISSAN dealership...he got the car back and it runs on C or just above..if the car sits for a few minutes at idle, it kicked up to where it used to sit half way between the C and the H before the water pump was put in. He also isnt get a good amount of heat in the cab...its warm but not HOT like it used to be when he set it to 85 (climate control)...the car no longer leaks but this is a big problem..when he drives the temp gauge is at or right about C...
My thaughts were:
Fans not plugged in-----they are
Fan Fuse's blew possible-----cant check its dark and cold out
or The Thermostat is bad (not operating properly) ??
any ideas please hit me back
-matt
Old Jan 7, 2004 | 10:17 PM
Wrightsfd's Avatar
Thermastat is always open
The thermastat is stuck in the open position. Take it back to the stealer and they (should) replace it or do it youself its easy.
Old Jan 7, 2004 | 11:41 PM
matty's Avatar
Definetly the problem ???
anyone else ??
-matt
Old Jan 8, 2004 | 12:14 AM
MaximamixaM's Avatar
Pretty darn likely the thermostat, if the engine temp is running only on Cold. If the engine was warming, and heat didn't blow, that could be tons of stuff. But likely bad thermostat. You could check radiator fluid, but since the car is running Cold, I doubt it. Fix the thermostat.
Old Jan 8, 2004 | 07:18 AM
JAY25's Avatar
thermostat. You said it no heat in cabin is the thermostat. Whats happening is recycling the water into the radiator not letting the engine warm properly. Hurts the car in many ways to include bad fuel mileage. Replace the thermostat and that should fixt the problem. replace it yourself, it only costs about $10.00 and three little 10mm nuts. How easy could that get? Let us know what happens when your done
Old Jan 8, 2004 | 07:35 AM
Show Maxima's Avatar
I second the thermostat theory, as its job is to remain closed and let the engine heat up and then temp. gauge will rise up, and afterwards it will open up at a predetermined temp. and let the coolant flow thru the rest of the system where it would be cooled off by the rad/fans combo. This is done because the engine is suppose to run at an 'optimal' temp. not cold, and not hot.
Old Jan 8, 2004 | 07:36 AM
Damn Jay beat me to it.
Old Jan 8, 2004 | 09:07 AM
JAY25's Avatar
what he said , what I said!
9aj9
Apr 5, 2020 12:11 AM
Smackasmith
Feb 1, 2016 12:40 AM
220k+ A32
Sep 11, 2015 02:18 AM
carid
Sep 9, 2015 05:06 AM
slowlifer
Sep 8, 2015 05:53 AM
