5 spd, Engine Hiccups shifting from 3-4th gear *Need help!
Old Jan 11, 2004 | 03:29 PM
maximumpower96's Avatar
This is my 2nd 4th gen max i have a 96 5 Speed maxima. Even my last maxima gave me the same problem. Going on high speed shifting from either 3rd to 4th or 4th to 5th my car 'sttutters' or take 'hiccups'. It become fines after doing that but its annoying as i cant keep a steading shifting the engine take 'hiccups' and looses some speed and then goes fine... i bet alot of people had the same problem please advice how can i get rid of this problem ?
-Sal
Old Jan 11, 2004 | 03:37 PM
Disregard, i searched and found it most likely it is my coil/coils.. but further info is much apprecaited.
-Sal
Old Jan 12, 2004 | 12:42 PM
DR-Max's Avatar
I never had that problem on my 5speed. BTW, I did replace my coils on time before it started affecting my engine performance. I also have a new set of NGK-V plugs so check your plugs too. Sometimes, the hiccup occurs when you are shifting erratically, not releasing the clutch pedal smoothly. Even though you are at high speeds, quick and smooth clutch release is key.
MAXSE5SPD
Sep 17, 2022 04:00 AM
sctludwig
Sep 1, 2022 01:32 PM
220k+ A32
Sep 11, 2015 02:18 AM
pjgreek
Sep 9, 2015 09:30 PM
dcardello
Sep 3, 2015 11:44 PM
