mum mum sound? wheel bearings?
Old Jan 11, 2004 | 08:39 PM
markargente's Avatar
Can't use the search for some reason. Im getting a mumming sound from my car and it is probably the wheel bearing. Could it be anything else? If so, how much would it cost to fix it? I think it's only coming from the passenger side front wheel. Any suggestions?
Old Jan 12, 2004 | 06:03 AM
knight71's Avatar
First, check to see if your tires are not defective, go to a tire shop and ask if they are before you spend $$ on wheel bearings...Good luck!
Old Jan 12, 2004 | 08:47 AM
Well, i already rotated the tires to see if they did anything and they are already balanced so i dont think its those
Old Jan 12, 2004 | 09:26 AM
Mishmosh's Avatar
If your tires are old or worn, there could be a lot of noise. I used to have a set of Dunlop D60 A2's and after about 20k miles on them, they were pretty damn loud. I wondered, like you, that maybe the wheel bearings or CV joints were bad but when I went to put on the winter set, the noise was completely gone.
Old Jan 12, 2004 | 09:32 AM
NmexMAX's Avatar
dot dot dot ...
If you do in fact need a wheel bearing(front), let me know I have one set for sale
Old Jan 12, 2004 | 10:49 AM
BORQUA79's Avatar
nycmaximas member
I hear that mumm mumm or humming sound when I get off of the brake at a stop... Then when I step on the gas it goes away??? Its just when Im at a stop? Is that the bearings or my brakes? and Its coming from the front passenger side aswell??? any suggestions?
bbsitum
Sep 6, 2019 07:31 PM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
boomerbrian
Sep 4, 2015 08:25 AM
maximusrising
Sep 2, 2015 09:55 AM
