Console Lights Illuminate Every Other Time -Please Help
Old Jan 12, 2004 | 07:45 PM
JetBlack SE's Avatar
My center consoles climate controls turn on every other time. During night time when i turn my lights on my controls illuminate sometimes but other times they are dead black and its a real hassle. I got a 95 se with analog ***** (no digital) please help me solve this before i use the dam thing with a flashlight. thanks
Old Jan 12, 2004 | 08:00 PM
recently i feel like i cant get any help here.... guys please respond...
Old Jan 12, 2004 | 08:03 PM
felix's Avatar
Sittin' On Chrome
it sounds like an electrical problem. maybe loose wire somewhere.
Old Jan 12, 2004 | 08:05 PM
edd's Avatar
edd
battery maybe?
Old Jan 12, 2004 | 08:14 PM
Ill break it down piece by piece....
Thermal **** (moves from cold to hot {blue-red}) on always
On-Off **** (1-4) lights once in a while
Buttons (where the heat/cold comes from) Never lit.
Old Jan 12, 2004 | 08:19 PM
SXN's Avatar
SXN
it sounds like a fuse problem. yea, org has been having some minor issues. please guys, hang in there, atleast keep the attitude positive
Old Jan 12, 2004 | 08:33 PM
felix's Avatar
Sittin' On Chrome
or the bulbs are burnt out.
Old Jan 12, 2004 | 08:42 PM
SXN's Avatar
SXN
but would they come BACK on if the bulbs were burnt?
Old Jan 12, 2004 | 09:06 PM
felix's Avatar
Sittin' On Chrome
that's the one i'm talking about.
Old Jan 13, 2004 | 09:16 PM
What would be my best bet of tackeling this problem. And is it easy to swtich the bulbs. Also the fuses are those located on the side under the sterring wheel? and last but not least where can i get a detailed blueprint of those fuses. pheeew thanks!
Old Jan 14, 2004 | 04:53 AM
RichMax's Avatar
Boosted like Snipes tax refund
sorry to "add on" But I'm having similar problems. People suspected it might be grounding...
Old Jan 14, 2004 | 09:40 AM
anyone else have any suggestions?
Old Jan 14, 2004 | 11:10 AM
soulrupture's Avatar
I would say rip it out and check and replace as you go. I don't have the search option and haven't found a how to to rip it out but thats what did with my speedo. It was going on and off so I ripped it out and replaced the bulbs. Turns out it was just the bulbs being loose in the holders. Good luck
Old Jan 14, 2004 | 11:21 AM
Whats the best way to remove the climate controls protion of the console?
Old Jan 14, 2004 | 09:12 PM
SXN's Avatar
SXN
i would suggest not doing what soulrupture...and ripping stuff out. i will look for dash removal tips right now.
Old Jan 15, 2004 | 12:01 AM
NISMOMAXMAN's Avatar
I've done this to hook up my stereo. You stick a flat head screwdrive w/ a cloth into the side of the console, where you have your clock, and emergency lights, and defogger. Push down on the console should pop off, be careful thou. Now you have the top portion off. Now you need to take off the part where you shift stick is at, same procedure, it should snap off. From there you almost done, on the top portion of the console, where your problem is orginating. You have two screws, but you have three more in the bottom, you'll see two after you take off the plastic on the shift. 1 will be right next to the ash tray.Open your ash tray, take it out, and inside there is a little screw, on the left side, look for it, and un screw it. You now will be able to pull out the console completly with the stereo and a/c connected. You can/should unplug all the harnesses when you take it out, and work from there. hope it helps
Old Jan 15, 2004 | 12:02 AM
sorry if I didnt make my self clear, but you can pm if you got questions.
trasmadean
Jan 20, 2018 05:05 AM
vingodine
45
May 21, 2016 12:46 PM
KristyKarina
Aug 23, 2015 09:53 AM
yat70458
Aug 3, 2015 01:16 PM
