LEDs in Climate Control
Old Jan 20, 2004 | 06:07 PM
enthused011's Avatar
Hey I have a 96 Maxima and a manual climate control. I was just wondering if anyone is good at these and could do mine for me...I have 5mm LEDs and the resistors. thanks alot.
Old Jan 20, 2004 | 06:24 PM
anyone know how to do this?
Old Jan 20, 2004 | 06:31 PM
sk24iam's Avatar
lol, If you find someone to do your led's that would be awesome. Try the northeastern though. Where on LI are you located?
Old Jan 20, 2004 | 06:42 PM
Im in North Babylon about 10 mins from huntington... I would ship it if I couldn't find anyone local though... I have everything else done in LEDs, except for the climate controls...there pretty hard, I took it apart and just didnt wanna mess with it
Old Jan 20, 2004 | 08:14 PM
ManualMaxima's Avatar
5th Gen till she dies!
try it yourself, you might be suprised.
Old Jan 20, 2004 | 08:48 PM
sk24iam's Avatar
Did you do everything else yourself?
Old Jan 20, 2004 | 09:29 PM
DAVE Sz's Avatar
Hooooooonda.....
So does anyone know the size of the small bulbs in the gauge cluster and the climate controls? They'de be easy to change but if one bulb costs like $3 then it's really pointless.
Old Jan 21, 2004 | 09:08 AM
Im not sure of the buld size... I just want the blue LEDs in there to match everything else
anyone?.....
Old Jan 21, 2004 | 11:36 AM
MadChef's Avatar
I have done this...which light are you referring to? The light that comes on when you select an air-flow option/AC/re-circ?
Or the back lights?
The back lights can be any size, but the lights underneath the buttons are a *****.
Basically they are very thin, and there is no way your 5mm bulb will fit. Not to worry though, you can dremmel opposite sides of the LED until it is flat enough to work. I did it, and it works great. You need to get the thickness down by about 50%.
Old Jan 21, 2004 | 11:57 AM
MaxiSpeed97's Avatar
^"thickness down by about 50%" of the LED itself?
Old Jan 21, 2004 | 12:24 PM
MadChef's Avatar
Correct. Think of it as flattening two opposing sides. Basically you are trying to put a thick round object into a thin rectangle...so you have to make the round object a thin rectangle =)
Old Jan 21, 2004 | 12:55 PM
Do you have any pics or your LEDs at night?
Old Jan 21, 2004 | 01:08 PM
MadChef's Avatar
Nope, I only did it recently, but it's pretty bright, and pretty cool. I could get some pics up, but it wouldn't be until thursday night.
Obviosuly it depends on how bright an LED you purchased...mine are 5000 mcd so they are pretty friggen bright....but that's all I had lying around.
Old Jan 21, 2004 | 07:08 PM
Thats cool, so all you gotta go is dremmel the sides of the led to make it rectangular, solder a resistor on, take the stock bulb out and solder the new one in? and also.... how do you get the dial out of the housing? that was the furthest i got when I took it apart, and I couldnt get it out.... It seems it has to come out before the circuit boards
Thanks alot
Old Jan 22, 2004 | 03:16 PM
MadChef's Avatar
Be careful dremmeling the LED's, just don't touch any metal! =)
Oh and you don't have to solder a resistor on.
The dial was a pain in the butt to get out...it does have to come out first. Basically get some small pliers and apply pressure straight out, then using a screwdriver you want to get it off the clips that are holding it on. (you can get at some inside, some outside) Trial and error, just don't pull so hard you break it =)
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
mpbclutch33
Dec 26, 2015 11:11 AM
RealityCheck
Oct 2, 2015 06:34 PM
