Porting ECU codes and car monitoring to a PC
Old Jan 23, 2004 | 10:56 PM
helaesus2's Avatar
Ok, can I get a scanner of some sort that will hook up to a PC? As some of you know, I'm doing a pc-in-car mod and want to integrate the car's systems with mine. Doing speed, mpg, distance etc would be helpful. Any ideas? EDIT: nevermind, I'm making good progress.
Old Jan 24, 2004 | 12:03 AM
DR-Max's Avatar
You'll probably have to have some sort of ODBII scanner that offers some type of PC software interface thru a serial port. BTW, I found this: http://www.scantool.ca/wgiobdiihw.asp . Hopefully this will stir you in the right direction. Good luck!
Old Jan 24, 2004 | 12:32 AM
helaesus2's Avatar
thanks. It's becoming apparent this is gonna take some hella long hours behind the PC to make this work.
Old Jan 24, 2004 | 02:06 AM
DR-Max's Avatar
Most definitely!!! Primarily because scanners/consults run under a proprietary platform (OS), such as found in something like a palm pilot. The only way to get a palm pilot to talk to a PC is via a software. The software is what translates information from one platform to another, in this case: ECU to PC. But things are much complicated to get that to work.
I haven't had a chance to look around the website I posted but have you found out how much their setup costs? I would imagine it costs a lot of money since this is the kind of stuff they use in the professional racing world. The race car's engine status and info can be monitored via some type of wireless technology by someone, most likely the race car mechanics, stationed in the pit while the race car goes around the track.
Old Jan 26, 2004 | 08:38 AM
astil's Avatar
This may help you...http://www.auterraweb.com/auterra/ I know that I m interested in this. Stevtec has one ,and if you reed the info ,it does quite good. You could find it on ebay if you look for it...
Old Jan 27, 2004 | 06:34 PM
97maxrob's Avatar
This site has/had free software and you can buy the unit for about $80.
http://obddiagnostics.com
But they are not accepting orders now due to illness
Old Jan 27, 2004 | 07:38 PM
michaelnyden's Avatar
i want to do the exact same mod in the near future....so helaesus2, just let me know how this all works out! this would make the car like a skyline in a sense....real time readings of injector position, timing, A/F ratio etc.....would be pretty cool to have that all displayed on an in dash 7" microvision display coming from a hidden laptop that is connected in some way to your car's ecu...!
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Roymg
Aug 17, 2015 02:44 PM
maxima297
Aug 3, 2015 12:50 PM
