Suspension Noise Please Help!!!
Old Feb 4, 2004 | 09:54 PM
chak210's Avatar
I have my 1999 GLE for more than a year. On last winter I started hear a cracking noise from front of a left side. Sometimes noise was gone then it appear again, so I changed my shocks and spring. After a couple of weeks noise appeared again, I went to mechanic he could't find a problem I went to another mechanic he could't figure out what is going on either, but noise getting louder and louder.
PLEASE HELP!!!
Old Feb 4, 2004 | 10:02 PM
sbslacker's Avatar
PLEASE HELP!!!
You changed it yourself? Did you replace any of the other rubber/plastic parts in there? Maybe the spring isn't seated correctly, or a bushing or something has worn out/come loose. Did you replace the strut bearings? Are the spring iso. wraps on (plastic tubing)?
Old Feb 4, 2004 | 10:09 PM
chak210's Avatar
Entire suspension laber was done by mechanic. When noise appeared I went back to him to check what is wrong he check everything but couldn't find anything. I was thinking about rudder control or steering.
Old Feb 5, 2004 | 12:31 AM
sbslacker's Avatar
If the car is stationary and the noises are only occuring when you are turning the steering wheel I would check the strut bearings.
Old Feb 5, 2004 | 04:46 AM
chak210's Avatar
actualy noise occuring during the ride without turning
Old Feb 6, 2004 | 07:29 AM
95Max's Avatar
Bad strut bearing will make noise if you are turning or not. Did you replace the spring isolators?
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
uttadms31
Sep 30, 2015 05:24 AM
