Jerky throttle below 2500 rpms
Old Feb 5, 2004 | 12:20 AM
guido32's Avatar
I cleaned my throttle body a little while ago and replaced the spark plugs. Ever since then I have a very jerky throttle below 2500 rpms. Basically, lightly accelerating causes the car to jerk. The same problem happens when I let off the trottle as well. The problem decreases as the vehicle warms up, but still exists. Any thoughts?
Old Feb 5, 2004 | 06:45 AM
95Max's Avatar
Get some turner cleaner from your local electronics store and clean your MAF
Old Feb 5, 2004 | 07:21 AM
nismos14's Avatar
§è~® f®ÈÄk
also, there is a possibility that your alternator can be going bad, does it whine alot?
Old Feb 5, 2004 | 09:14 AM
PoePoe2797's Avatar
I have the same jerkyness when on the throttle and off the throttle. I haven't eveactly found out what the problem is but I think it has something to do with the IACV kicking on and off. I cant see how the alternator has anything to do with this ...maybe the MAF
Old Feb 5, 2004 | 11:35 AM
DAVE Sz's Avatar
Hooooooonda.....
I kinda have the same thing, kinda. I have an auto BTW. Anyway it revs quick til about 1800rpm then around there it just starts struggling. If I give it a bit more gas it gets to around 2200rpm and this surge of power comes on. I believe it can be fuel injectors or knock sensor. I know that I have bad fuel injectors since I replaced everything else.
Old Feb 5, 2004 | 02:44 PM
95Max's Avatar
The IACV is for idle. Do the rpm jump around at idle? No? move on
A bad MAF can cause the to surge, jerk and even buck if the MAF is really bad.
I cleaned my MAF and much better. Make sure you use a cleaner designed for electrical parts
Old Feb 5, 2004 | 02:58 PM
nismos14's Avatar
§è~® f®ÈÄk
the alternator can cause this problem, bc it did in my car. as far as why? because when the car is accelerating, the alternator has no load on it, when u aren't accelarating and ur just letting the car roll, if the alternator is bad the car will jerk alot (this is just what happened in my car
Old Feb 5, 2004 | 03:10 PM
PoePoe2797's Avatar
Would a malfuctioning MAF causing the jerkyiness trip a CEL or store a code. Checked the ecu and got nothing. I'll clean it tommorow and let everyone know if that solved it. I also heard alcohol cleans MAF's pretty well, also brake cleaner
Old Feb 5, 2004 | 03:13 PM
Kevlo911's Avatar
Kevlo for President
Clean the MAF with Rubbing Alcahol. Clean the TB and IACV, both how to's are found in the 4th gen HowTo's
Old Feb 5, 2004 | 03:45 PM
guido32's Avatar
I don't know what alternator whine sounds like. The only whine I hear is at low rpms when I am slowly accelerating in town. Is that it? I will try to clean my MAF first, thanks for the heads up.
Old Feb 5, 2004 | 04:03 PM
nismos14's Avatar
§è~® f®ÈÄk
do u hear it in all gears? if you hear it, and it becomes louder with the amout of acceleration, and then goes away sometimes, u prob need to have it checked out, but if you have it checked, dont tell the place that your having it checked that thats what you think the problem is, they will just say yea, its bad, replace it and charge you an arm and a leg, make sure you have a good shop take a look at it.
Old Feb 6, 2004 | 07:04 AM
95Max's Avatar
Do not use brake clean on the MAF. I tired the alchol methold first no real diff. Used Contact cleaner...car much happier.
Old Feb 6, 2004 | 07:25 AM
Xugg's Avatar
lol, contact solution, doubt that did the trick??? I just used some Carb Cleaner on the MAF after i was done cleaning the TB and IACV and it seems to be happy.
Old Feb 6, 2004 | 07:39 AM
95Max's Avatar
Electrical contact cleaner you rocket scientist. Carb cleaner is not designed for electrical componets.
Old Feb 6, 2004 | 08:53 AM
PoePoe2797's Avatar
Hmm...i was always told brake cleaner is pretty much the same as electrical cleaners...
Old Feb 6, 2004 | 05:30 PM
guido32's Avatar
Are there any instuctions in the forum as to how to clean the MAF? I know that this is an expensive part and I don't want to damage it upon cleaning.
Old Feb 11, 2004 | 07:44 AM
95Max's Avatar
Simple.
1 remove maf
2 spray sensor wire (with cleaner for electrical parts)
3 install maf
Old Feb 11, 2004 | 09:14 AM
PoePoe2797's Avatar
I just cleaned mine and the jerkyiness is still there.....looks like its something else
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
