Power Slot Rotor question
Old Feb 19, 2004 | 12:15 AM
Max96LSU's Avatar
I'm due for a complete brake job and I know I have to change my rotors quite soon as well. Do anyone of you have the Power Slot rotors on your car? Any signs of rusting or corrosion? I saw that Custom Maxima sells them but I want to get some personal reviews before I decide to buy them. Pics would be great too!
Old Feb 19, 2004 | 04:36 AM
d_warner's Avatar
Old Timer
Oh. I can show you pics of mine after just one year. You wont like it though. The fronts are cracking near the cross drills. I will never again do cross drilled rotors. I will do slotted, but not cross drilled. I would suggest Matt's Big brake kit. He is working on a kit for use with stock calipers. Your only problem might be rim size. If you can't do that, I would do regular slotted rotors. Not cross drilled. Just a sec, and I'll go take some pics right now.
-David-
Old Feb 19, 2004 | 04:47 AM
d_warner's Avatar
Old Timer
Not only do the powerslots look like this after only one year, but the initial bite is crap due to the lower surface area, and it requires much much more pedal to stop the car. You literally have to stand on the brake pedal if you want to stop in any sudden emergency braking situation. I hated them, I will always hate them, and unless you are running a 4 piston caliper or larger to apply more pressure and are using them in a race setting, I would never get them again. IMHO, Definately not worth the money. Get stock replacement rotors, or just slotted rotors.
-David-
Old Feb 19, 2004 | 06:14 AM
Skyboarder's Avatar
What is Matt's big brake kit?
Old Feb 19, 2004 | 07:23 AM
eckohb's Avatar
he was asking about the power slot rotors, they are only slotted, not drilled.
Old Feb 19, 2004 | 07:31 AM
BuNGsVQ's Avatar
Power SLOTS are drilled now o.O
Old Feb 19, 2004 | 07:43 AM
endus's Avatar
An atavistic endeavor...
I'm interested in what people are running for brakes as well. I'll probably need a brake job sooner than later and want to do soemthing aftermarket. I know different pads with stock rotors will tend to squeak, but I'm pretty sure there's a combination of rotors and pads that will provide better performance than stock and not squeak...I'll ahve to search and see if I can find it.
Old Feb 19, 2004 | 07:51 AM
eckohb's Avatar
not the ones for the 96 maxima on custom maxima which he said he was looking at. http://www.custommaxima.com/PowerSlot.php
Old Feb 19, 2004 | 08:18 AM
mitch33x's Avatar
All drilling and/or slotting does is create an unever rotor surface. Which leads to increased pad wear, and cracking/failure.
Save your money, get some aftermarket blank rotors
Old Feb 19, 2004 | 09:02 AM
Max96LSU's Avatar
thanks for all the replies. I know that drilled rotors tend to cause problems with cracking and wearing down the pads faster. Will the slotted rotors also cause the pads to wear faster? If so, i'm going to take mitch33x's advice and just get some brembo blanks most likely. Which brake pads should I incorporate with my new rotors? I've heard Axxis and Hawk pads are good. Which do you guys have on your ride and do you recommend them?
Old Feb 19, 2004 | 09:20 AM
mitch33x's Avatar
check out this recent thread
http://forums.maxima.org/showthread.php?t=274201
Old Feb 19, 2004 | 09:26 AM
VQvroom's Avatar
i agree. i purchased my brembo OEM replacements from tirerack.com
they arrived within 48 hours after the order was placed.
Old Mar 7, 2004 | 05:54 AM
cobraman's Avatar
power slot rotors
I installed the sloted Power Slot rotors (without drilled holes) along with four new rebuilt caliipers and Hawk front pads. I think the silver coating is misleading. The brakes pads wear it off like in a day and the surface rusts (like any other rotor does). The coating on the non abrasive surface has held the coating though (so far). To me it sounds like the slots make whirling sounds while driving (w/o applying brakes). The performance is pretty good, better than stock. If I had to do it again I would get non-slotted and put hawk pads in the calipers.
Old Mar 7, 2004 | 08:34 AM
Max96LSU's Avatar
cool thanka for the input
The Frye
Sep 2, 2021 11:03 AM
AT978
Sep 6, 2015 10:31 PM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
