battery not holding charge
Old Feb 19, 2004 | 07:22 PM
Johnny01001's Avatar
Help!!!!!!!!!!!!!!
Hey guys, im new, and my english is poor (SXN helped me write this) so bear with me!
The other day, i left my head lights on for a few hours, then later driving around, my car just died. I took it to an auto parts store, and they checked and charged the battery for me. they said the battery was not recieving a charge from the alternator. i then replaced the alternator, and the battery is still not holding a charge. It wont start now. The alternator is hooked up properly, and all the belts are good.
I have a 1995 se 5 speed, and ANY help would be appreciated. Please be patient with my english, it needs a lot of work!
thanks to SXN
Old Feb 19, 2004 | 07:24 PM
Cal0205's Avatar
Replace the battery?
Old Feb 19, 2004 | 07:25 PM
SXN's Avatar
SXN
ok guys...here is the deal with this guy
he's pretty good with cars (did the altenator himself) but his english isnt good. he was afraid of posting because of it. Just go easy on him, while talking to him, he has never been hard to understand, just some bad grammar here and there. help if you can
Old Feb 19, 2004 | 07:37 PM
98SterlingMax's Avatar
Humble '06 TL Owner
I would just replace the battery (you might need a new one anyway) the car should start and then measure battery voltage at the terminals, if the alternator is doing it's thing properly you should see 13.3 volts or a little higher at normal idle, if not you have other problems.
Old Feb 19, 2004 | 07:50 PM
2 Da Max's Avatar
his english seems fine to me.
Old Feb 19, 2004 | 07:56 PM
ABK's Avatar
ABK
I would guess that it's a messed up battery. I would take the old alternator and get it tested at autozone. Also check the fuses. Keep us posted, don't afraid to write we don't flame for bad english.
Old Feb 19, 2004 | 10:01 PM
SXN's Avatar
SXN
because i wrote that post. he was afraid you guys would make fun of him.... what could have possibly made him think that?
he had the battery tested and charged (generic auto parts store....he doesnt know which) and they said his battery was fine. doesnt mean it isnt the battery, but just letting you know
Old Feb 19, 2004 | 10:07 PM
ABK's Avatar
ABK
get it checked at autozone, make sure that they pressure load test it. that generic place prolly did the voltmeter test which doesn't prove $hit, sorry for the language.
Old Feb 21, 2004 | 05:13 AM
Kevlo911's Avatar
Kevlo for President
Yes, Let Autozone check it with thier little portable machine, it will tell you how many amps and volts are comming.
Also when you installed the alternator, did you make sure that the small 2 pin harness was in all hte way? Mine was not and I was about to replace hte alternatior again because of that. They person who installed it did not do a good job, so make sure ALL THE CONNECTIONS ARE GOOD. Also, are your brake and battery lights on in the dash? IF so, check the fuse, it is under the hood near the battery, it is labeled ALT--I think.
Pnjboyzz
Nov 16, 2015 12:27 PM
AboveDaCloudz
Oct 8, 2015 11:25 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
bigfrank
Oct 1, 2015 12:51 PM
