How do you clean the engine room?
Old Feb 20, 2004 | 06:52 AM
keehoon's Avatar
Is it harmful pouring water into engine room?
you guys, please let me know how to do that usually?
Old Feb 20, 2004 | 07:17 AM
felix's Avatar
Sittin' On Chrome
pretty sure it is. you might want to check out the Detailing Forum --- http://forums.maxima.org/forumdisplay.php?f=69
Old Feb 20, 2004 | 09:52 AM
Jatan's Avatar
We call it an engine bay
Old Feb 20, 2004 | 09:54 AM
eckohb's Avatar
so is spraying it down at a DIY car wash bad for it?
Old Feb 20, 2004 | 09:56 AM
felix's Avatar
Sittin' On Chrome
are you serious?
Old Feb 20, 2004 | 09:57 AM
Noslen's Avatar
especially with a high pressure hose! BAD IDEA!
Old Feb 20, 2004 | 10:05 AM
eckohb's Avatar
yes, i was serious, thats why i was asking...at some it has an engine cleaner you can select, so thats why i asked the question. sorry for being a dumba$$
Old Feb 20, 2004 | 10:09 AM
96explorerxlt's Avatar
I used to do this with my Explorer all the time, never had a problem. I just covered up the alternator and the battery, and a few other things and went to town. Never had any problems. (might be different on the maxima). I just made sure it was cool enough however so I didn't crack the block.
nismology's Avatar
You should never ever hose down a hot engine. Ever....
Old Feb 20, 2004 | 10:15 AM
felix's Avatar
Sittin' On Chrome
Nah, it's cool bro. It's just a lot people on here joke a lot, so I wasn't sure. Didn't mean to offend you.
Old Feb 20, 2004 | 03:29 PM
wariow's Avatar
i think they clean the engine with steam and degreaser but I'm not sure. I don't like the idea of just pouring water over it. It's most likely not gonna clean crap, just make the engine have concentrated dirt spots, damage some electrical component or cause rust formation.
Old Feb 20, 2004 | 03:36 PM
DJMaxGLE's Avatar
Maybe OT, but this reminds me of a kid I once saw driving an old Celica with no hood. What would he do when it rains?
Old Feb 20, 2004 | 03:37 PM
98SterlingMax's Avatar
Humble '06 TL Owner
I spray it every now and then at the coin-op car wash, no problem. Just make sure the engine is cool or barely warm (I take it right around the corner, never gets even warm) and don't blast anything with the jet close. Definitely put a plastic bag over your HAI if you have it.
Old Feb 20, 2004 | 03:42 PM
Jatan's Avatar
http://forums.maxima.org/showthread.php?t=259510
http://forums.maxima.org/showthread.php?t=275421
When you go to a coin-op, don't press the spray lever, just let it drizzle onto the engine bay. Then you can turn on the rinse cycle and let it drizzle the water.
Old Feb 20, 2004 | 04:10 PM
hotshtsr20's Avatar
i cleaned my engine just yesterday.
Make sure to cover the alternator, top of battery and any open inlets (intake, etc). hard water can conduct, and although it wont create a fire, it can drain the battery. i used ceran wrap.
cool engine, sprayed it down with 100% Simple Green. Soak. Sprayed again, and scrubbed down all the stuff that wasnt readily running off. sprayed the simple green and grease off with a light mist on the hose until totally rinsed.
LET DRY! i left the hood up in the sun all day (gotta love san diego!). started it up, no problems.
i have been doing this for years, never had a problem (except on my SE-R when i forgot to cover the distributor. strangely, a wet distributor doesnt work let it dry, no problems)
Old Feb 20, 2004 | 04:41 PM
2 Da Max's Avatar
do wat i do and drive it into the ymca pool, man that chlorine is strong.
Old Feb 20, 2004 | 05:09 PM
Maxima99SE's Avatar
will fly for food
Old Feb 20, 2004 | 05:28 PM
gtr_rider's Avatar
192.168.1.1
Originally Posted by Maxima99SEbose
Anyhow.. I usually use Simply green on the engine, when it is cool and let it set coating all the grease for 5 minutes and then I spray it down with cool water. Does the trick, only thing I havent figured out is how to grease the hoses properly *no armorall*
Old Feb 20, 2004 | 05:43 PM
mansurxk's Avatar
used to do it on my 94 accord, cover the alternator, starter, fuse boxes, and battery make sure the engine is barely warm, and use as little water as possible, scrub the grease free after you spray it with degreaser, that should do the trick, but i wouldnt recommend doing it because there could be an exposed wire anywhere
Old Feb 20, 2004 | 05:46 PM
maxima98vspec's Avatar
its safe if u know what ur doing, cover ur intake if u have one, and just spray away, i did it not to long ago, i used a degreaser and some other soap stuff and i washed it down. it came out preaty good.
Old Feb 20, 2004 | 07:33 PM
2 Da Max's Avatar
Whats wrong with that? i got a full membership at the YMCA plus i use the guest pass for the max.
The Frye
Sep 2, 2021 11:03 AM
6spd4dsc
Mar 4, 2016 05:19 PM
03VQMAX
Sep 5, 2015 03:47 PM
crazyespn
Sep 3, 2015 01:30 PM
