99 SE-L ECU Prob -- No Screw??
Old Feb 23, 2004 | 08:21 AM
T.Maximus's Avatar
You guys have been great bearing with me but I'm stuck...
There's no silver screw showing in the adjustment hole on the ECU. What is see is a small white plastic gear, sort of off-center. What's up with that? The clear label is untouched so I don't think anyone's been in there.
(Also the hole is also labeled for idle adjustment, fast to slow.)
Your help sincerely appreciated!
T.
'99 SE-L
charcoal/silver
55K
Old Feb 23, 2004 | 09:39 AM
max7's Avatar
The idle **** is used to check for codes. Turn it left for the full circle wait two seconds and two full circles right. The codes should start flashing. Hope this helps!
Old Feb 23, 2004 | 09:53 AM
T.Maximus's Avatar
Hey 7 -- thanks for your reply. As to idle ****, are you talking about what I see in the hole on the ECU where the silver screw should be?
T.
Old Feb 23, 2004 | 09:57 AM
Pearl99GXE's Avatar
Be very carefull. It is easy to break that screw off.
Old Feb 23, 2004 | 10:02 AM
Jr'sMaxima's Avatar
I also thought it was a pain in the a, but you need a really small screw driver and be very careful with it, it feels much inferior to what my 95 did.
Old Feb 23, 2004 | 10:06 AM
T.Maximus's Avatar
Jr -- I just want to be clear. You're talking about the small white plastic thing I see in that hole on the ECU? Do you agree with the above message about turning it a full counterclockwise circle then back two circles to get the code?
Thanks!
T.
Old Feb 23, 2004 | 10:13 AM
fisher01's Avatar
Thanks!
T.
Thats the screw to turn. Its located downward and to the left. Use a small screwdriver like the ones for eyeglasses. be carefull turning, its delicate. Follow instructions for the previous years and you will be able to get the codes.
Old Feb 23, 2004 | 10:20 AM
T.Maximus's Avatar
Whew, they're not making it any easier. Thanks -- will give it a try!
Old Feb 23, 2004 | 10:22 AM
infinitiblast's Avatar
Its much easier to just got to autozone to get teh codes..for freee..rather then bust your head, trying to see the little screw finding a small enough screw driver to fit it........etc.etc..........
just my 2 cents........
Old Feb 23, 2004 | 10:44 AM
T.Maximus's Avatar
Does Autozone hook up a diagnostic tool?
Old Feb 23, 2004 | 10:46 AM
Yes they do...the actron obd 2 scanner and then they can even look up the codes for you
Old Feb 23, 2004 | 10:49 AM
max7's Avatar
Autozone is great with that. I've had them do it once!
Old Feb 23, 2004 | 10:57 AM
Brudaddy's Avatar
Max7, love your rim/body kit set up on that 4th gen. That is tight looking...but clean and not ricey!
Old Feb 23, 2004 | 10:59 AM
T.Maximus's Avatar
Thanks all.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
