Cv Joint Replacement
Old Feb 24, 2004 | 08:33 AM
JWYLES's Avatar
MY '97 needs cv joints. Is it a job that can be done by myself or are there special tools involved ? How long would it take to do?
It looks like I am going to have to go for the entire axle assy.
J wyles
Old Feb 24, 2004 | 09:02 AM
I30tMikeD's Avatar
www.motorvate.ca
Old Feb 24, 2004 | 01:03 PM
nismology's Avatar
That site doesn't show how to replace the joint but only how to replace the outer CV boot. I suggested that he added a how-to on changing the joint itself but he hasn't responded yet...
Old Feb 25, 2004 | 06:47 AM
JWYLES's Avatar
Your right,
Not a lot of detail there to do the whole job.
I have looked at a Haynes manual and there is not alot of detail there either. I don't want to drop about $400 for a garage to do the job if it's not that difficult.
So if anyone has the details on what's involved let's hear it.
J Wyles
Old Feb 25, 2004 | 07:02 AM
shnoog's Avatar
honestle what i have found for simplicities sake is go to advance auto parts or a store like it and buy a whole new axle. THe price and the labor intensity of the job decreases. changing the axles in your driveway only takes a few hours. I have done this on 2 vehicles so far.
Old Feb 25, 2004 | 07:26 AM
JWYLES's Avatar
That looks like the way I am going to go. Complete axle assemblies.
Have you done them on your Max?
I have a 5 speed if it makes a difference.
Old Feb 25, 2004 | 07:45 AM
SkinnyMax's Avatar
maxima no more
its not worth the time of disassembling the CV joints when the axles are so cheap and such a time saver. its a pretty easy job, the only trouble I ran into was getting the axle to separate from the support bracket. after a removing the bracket with the axle and a few convincing blows with a sledge it decided to come apart.
Old Feb 25, 2004 | 07:54 AM
dizmax96's Avatar
axles
look at it this way.. your joints are gone. get axles.. they are cheaper. to do the job will be difficult if done at home. i work on my car at the dealership that i work at.. its easier on a lift and having compressed air and tools on hand. it will be time consuming using hand tools but it can be done. you dont need special tools.. just a lot of patience.
Old Feb 25, 2004 | 08:07 AM
shnoog's Avatar
yep alot of patience, I have done this on mine and it isnt too fun on the passenger side. The only tools that you really need are a good socket set. a pry bar, hammer, and a good set of wrenches.
Old Feb 25, 2004 | 08:35 AM
JWYLES's Avatar
From what I have gathered thus far it seems to be a given that the seals at the tranny where the axles go in also should be replaced.
I also have heard that I need to know whether I have a limited slip differential. (probably not in a GXE)
Old Feb 25, 2004 | 10:36 AM
SkinnyMax's Avatar
maxima no more
when I was replacing my axle, I gave Raxles.com a call to price axles and I also asked them if I needed to replace the seal, he said that if its not leaking now don't touch it.
Old Feb 26, 2004 | 07:13 AM
JWYLES's Avatar
Is the nut on the end of the axles 36mm? I have a '97 GXE
I'd like to find out without having to take a wheel off so I can go and get a socket today. (wheel covers are held on by lug nuts)
jwyles
Old Feb 26, 2004 | 07:21 AM
SkinnyMax's Avatar
maxima no more
when I got my new axle it came with a new nut on it, so if you could just take that nut to the store and figure out which one fits. I would assume it is a 36mm like my '96.
Old Feb 26, 2004 | 08:35 AM
RyCrisp's Avatar
I am doing my axles tomorrow, I got mine from raxles.com for 119 for one side and 149 for another. One side went up like 20 bucks in price since I bought mine but mine did not come with new nuts.
Old Feb 26, 2004 | 10:53 AM
maxcross's Avatar
don't bother...just replace the axle...talk to Marty at Raxles.com
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
