Right Front Wheel turning in Neutral!
Old Feb 24, 2004 | 12:11 PM
95MaxSE's Avatar
95 GXE, Manual transmission.
I had both front wheels jacked up to replace the oil pressure switch. After replacing the switch, I turned on the engine to check for leak. At this time, both front wheels were still in the air. Even in neutral, the passenger side wheel is turning at about 5 revolutions per minute. The force exerted on the wheel is relatively weak, as I can stop it with my hand, but as soon as I removed my hand, it started turning again! (The driver side wheel never moved)
What causes the right wheel to turn? What is the fix?
Thanks guys,
Sam
Old Feb 24, 2004 | 12:30 PM
PAREDLINE's Avatar
There is no fix. There will be some transmission of torque when the clutch is engaged- I believe this is to circulate transmission fluid. I may be wrong about that.
You see this in almost every car.
If you floor the clutch and you still have this happening then there might be something wrong.
Old Feb 24, 2004 | 12:44 PM
98SterlingMax's Avatar
Humble '06 TL Owner
What is happening is with the clutch engaged in neutral the main shaft is spinning at engine speed and the gears attached to it are churning the relatively thick gear oil and the other gears are turned by this moving oil causing the wheel to turn.
Old Feb 25, 2004 | 07:12 AM
95MaxSE's Avatar
Thanks guys. But why only the right wheel? Why isn't the torque transferred to the left as well?
Old Feb 25, 2004 | 07:49 AM
SkinnyMax's Avatar
maxima no more
its going to turn which ever one has the least resistance, unless you have a limited slip diff.
trasmadean
Feb 1, 2017 08:20 PM
homeyclaus
Sep 3, 2015 06:15 PM
official_style
Aug 29, 2015 10:10 AM
twotonezed
Aug 16, 2015 11:41 AM
BassAddictJ
Aug 4, 2015 11:38 AM
