Help changing PCV Valve...
Old Feb 26, 2004 | 08:31 AM
kendrickc's Avatar
I found pics on changing the PCV Valve, but I don't see anything on how to actually change it. It appears to be held by a clip, but I don't see a way to actually get to it.
Since I only find pictures of the location, I assumed that it's a easy change. I must be missing something really easy. Please help me out.
Forgive me for this question...
Old Feb 26, 2004 | 08:47 AM
dmplus's Avatar
small 4 inch or so hose no too far from the throttle body. It has clamps on both ends you will need to loosen then pull the hose off the pcv, pull the pcv put new one in, replace the hose. Only hard part is there isnt much play in the hose. Just be patient.
Old Feb 26, 2004 | 10:06 AM
wildmaxi's Avatar
where are the pics...can you post or just tell me where the PCV valve is..pic is better thatnks
Old Feb 26, 2004 | 10:11 AM
kendrickc's Avatar
Here is the pic
Here is the pic
http://web.archive.org/web/200108260...v_location.jpg
Old Feb 26, 2004 | 10:13 AM
sadice's Avatar
it's right next to TB it's in the block with a hose attached to it mine is actually blue if it's stock then yours should be too. when u open the hood stand in the middle at the front and bend down and look down bfore u reach tb u'll c a little opening in the block and u'll c the hose going in thats the PCV.....
Old Feb 26, 2004 | 12:51 PM
kendrickc's Avatar
So are you saying to take the entire hose off, replace the pcv and then put entire structure back on. I assume this is a job for one with small hands...
How long did it take to get the hose back on. mine is obstructed a little. Not real easy to get to.
Old Feb 26, 2004 | 08:22 PM
dmplus's Avatar
Me and a friend worked together on it with pliers screwdrivers etc.. So we had 4 hands on it. Toughest part is getting the new one back in.
doctorpullit
Mar 29, 2016 11:08 AM
MaxLvr21
Oct 17, 2015 12:11 PM
jds22
Sep 29, 2015 02:03 PM
Noela
Sep 26, 2015 08:22 AM
