noise after FSTB install
Old Feb 29, 2004 | 04:36 PM
kwharrigan's Avatar
After installing a courtesy FSTB I have encountered a strange creaking noise. This happens on launches, after slowing close to a stop, and going over bumps at < 30mph. I took the strut brace off (leaving the brackets attached) and the noise went away. Can anyone give me some tips on how to alter my install to make this noise go away?
Old Feb 29, 2004 | 05:31 PM
ManualMaxima's Avatar
5th Gen till she dies!
man whyare there so many problems with stut bars.......makes me afraid to put one on. Did you tighten it correctetly?
Old Feb 29, 2004 | 05:45 PM
kwharrigan's Avatar
Yes, the strut mounting nuts have been tightened to 35ft-lbs. I'm not sure if this is enough as some people have quoted the stillen as saying 46 or so. The shop manual I have says the range is 29-40. The install is very very easy and it really kicks *** as far as handling goes. I just get this strange creaking noise, seemingly when there is a lot of forward/backward movement in the suspension. Any ideas guys?!
Old Feb 29, 2004 | 06:27 PM
Polish_Maxima's Avatar
I had the same thing happen after I re-installed by strut bar (too it off to replace fuel filter [ FF = evil!!!] ) ... for it ... it just went away after I tightened the bolts a bit more ... not too much more though, I only once in a long while (like once every 10,000) hear a creak. So maybe try tightening it some more.
ManualMaxima - problems with strut bars? not really ... as far as I see it's one of the easiest mods to do and it really helpfull on them fast corners ;-) You should have nothing to be afraid of ... well ... unless you get a wierd one and have to slightly move the AC Line (like I did) just so the two don't rub = bad ... other than that install one!!!!!!!!
Old Feb 29, 2004 | 08:40 PM
tm96max's Avatar
I had the same problem. Check the middle part of the engine where the bar almost or does hit some lines near the intake manifold. I just bent those lines just a bit to stop the noise.
Troy
Old Feb 29, 2004 | 10:22 PM
Keith P's Avatar
I had to push some AC lines down on the right side. More like banging.
MaxLife17
Jun 27, 2019 01:37 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
