removing grille
Old Feb 29, 2004 | 06:06 PM
mendon11's Avatar
removing grille
so iwas going to do the ae headlights today but i couldnt get the stupid grille off! i know that you have to turn that little square "screw" thing but i cant seem to get a flathead in to turn it nor can i turn it from behind. HELP! i have the paint sitting in my garage and my lights are begging to be painted.
thanks
-mike
Old Feb 29, 2004 | 07:47 PM
WizzaMax's Avatar
you dont twist it...they are popped off with a flat head from in front of the mounting clip you are referring to...use a slim flat head and wedge it from the front portion of the grill and that pair of diamonds will compress and the grill will pop forward slightly...then you can remove it with some mild pressure.
Old Feb 29, 2004 | 07:48 PM
2 Da Max's Avatar
dam mines wont go back on
Old Feb 29, 2004 | 08:00 PM
mendon11's Avatar
THANK YOU! although i think i may be a little confused. so from the front of the grille wher ei can see the diamonds, i stick a flat head in that small hole and pry, or do i pry from the top of the grille?
Old Feb 29, 2004 | 09:26 PM
(_8*(l)Homer's Avatar
Just grab the grill and pull up and out. Don't be afraid of force.
Old Feb 29, 2004 | 09:39 PM
MrDicks95SE's Avatar
Offset Is Everything.
when i did my ae's i didnt pull the grill out. i just left it in there but i had to twist it sideways a bit.
Old Mar 1, 2004 | 08:47 AM
soccstv's Avatar
i'm also trying to remove my grill, but having problems. wizzamax, i'm having trouble picturing what you're saying about putting a flathead in the front portion of the grill where the diamonds are. could you possibly post a pic of what we're supposed to be looking for? thanks
Old Mar 1, 2004 | 04:16 PM
ManualMaxima's Avatar
5th Gen till she dies!
lord my girlfriend took it off without even asking! shame shame
Old Mar 1, 2004 | 04:44 PM
soccstv's Avatar
well good for you and your girlfriend...that still doesn't help
Old Mar 1, 2004 | 04:57 PM
well good for you, you still have a problem getting it off.....i was just stating it is not that hard just go out there and try.
Old Mar 1, 2004 | 05:05 PM
mendon11's Avatar
i tried for a while and still couldnt get it...although i didnt try to pry or pull on it like you guys said to do because i was afraid of breaking it. guess i should give it a go.......
Old Mar 1, 2004 | 05:08 PM
yea just stick a flat head between the grill and body of the car where the connectors are and just pry them out....then just take the grill my the painted bar in the middle of it and just pull up slightly and out with alittl ebit of force
Old Mar 1, 2004 | 05:15 PM
mendon11's Avatar
those were teh best directions yet...straight and to the point. thanks!!!!!
REDinLV
Aug 15, 2024 12:30 AM
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
ricky7780
Sep 24, 2015 06:50 PM
