Power antenna not working. Is this what i need to fix it?
Old Mar 2, 2004 | 02:27 PM
steveme's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=33639
The motor works when i turn on the FM/AM, but there is no antenna. It is how I bought the vehicle. Is that all I need to fix it.
Thx
Old Mar 2, 2004 | 04:09 PM
venompwr2's Avatar
Thx
Well if there is no antenna then that's what you need. Do you get reception w/ the radio? Because maybe someone put in a diff antenna.
Old Mar 2, 2004 | 04:22 PM
steveme's Avatar
FM works am is not so much. there is no antenna. Its just the hole going into the motor. the previous owner said it was broken and never fixed.
Old Mar 2, 2004 | 04:25 PM
venompwr2's Avatar
Then go get a new antenna. I had a different problem, the headunit I had didnt have a wire to use a power antenna, so the radio had no reception- or at least very poor. So I had to rig up a switch to use the antenna.
Old Mar 3, 2004 | 06:02 AM
jguillory's Avatar
As long as your motor is working, then the mast off of e-bay is what you need. I purchased the same/similar mast a few months ago. My antenna was in place; it just didn't go up and down.
The only possible problem is that there is a broken piece of the plastic thread from the antenna still down in the motor. If you get the new mast, you will need to turn the radio off, so that the motor tries to retract the antenna. While the motor is doing this, feed the new thread down into the hole and it should grab on.
If there is a piece of the old thread in the motor, you will need to remove the motor from the side-wall (inside the trim panels inside the trunk), take it apart and remove the old piece. Good luck
lowpost99
Oct 26, 2025 06:53 PM
Smackasmith
Feb 1, 2016 12:40 AM
Maxie40
Sep 14, 2015 11:28 AM
Violator
Sep 9, 2015 10:14 AM
