strut bearing
strut bearing
I need to get alignment soon. My strut bearings are also bad. Do I need to replace the strut bearings before alignment? Does this 2 things relate each other?
thanks for any help.
Originally Posted by Big D
You don't have too, but why would you get an allignment when you know parts of your suspension are messed?
Not sure. Why not replace the bearings and do the allignment after?
Thx for ur inputs.
The things you should check are the ball joints and tie rods.
It could depend how bad the bearings are. If one side is shredded/disinegrated then the shalf will lean slightly and that would affect the align readings.
If it were me I'd get in there and replace the bearings, inspect the strut mount, bushings, bumpstops, etc. The alignment won't mean much if everything wobbles around when pushed anyway. Take it from me. I've had 12+ alignments and continue doing about 2-3/yr.
P.S. Trying to decide if it's worth $500 to build custom mounts/plates. You know, metal bearings, something better quality than the Stillen plates I already have
litch
123
01-04-2024 07:01 PM
maxima-junky
10-07-2015 06:13 PM
220k+ A32
25
10-03-2015 09:09 PM
Andy29
09-29-2015 05:32 AM
