Keyless remote progam instructions with question.
Old Mar 8, 2004 | 10:43 AM
steveme's Avatar
I did this and the hazards flashed. I then put the key in the ACC position and pressed the lock on the remote...nothing. Bad remote? I switched batterys to a new one as well. 1995 max gle.
0-
Get in the car. Close and lock all doors with the driver's switch. Insert and remove the ignition key over six times in l0 seconds. Do it at a rate of one insert/remove cycle per second. Be sure you completely remove the key each time. Turn ignition to ACC and press any button on the remote once. If the hazards flash twice, it worked! If you want to program more than one remote, unlock and lock the doors again with the driver's switch and press a button once on the next remote.
0-
Old Mar 8, 2004 | 01:53 PM
Crazi nismo's Avatar
I'm just curious...who can open thier front windows w/ thier remote...if haven't tried unlock the car and hold the button for unlocking the car and they should open
Old Mar 8, 2004 | 02:10 PM
DrX's Avatar
DrX
I can...98 se
Old Mar 8, 2004 | 03:47 PM
ShRapNeR's Avatar
I just bought a remote from ebay..
i read the instructions and still had trouble
guess i didn't read all the instructions
Get in lock doors using driver switch insert key over 6 times in 10 seconds.. put in acc position press button on remote. remove key
unlock the doors using the driver switch and then open the driver door
that worked for me
except my horn button don't work.. but thats probably the car not the remote.
Old Mar 8, 2004 | 05:34 PM
NISMOMAXMAN's Avatar
Check if its not a altima control, I had a problem similar like that, only to find out I purchased a altima remote advertised as a maxima remote. Oh and I can roll my windows done too.
Old Mar 8, 2004 | 05:47 PM
mclarke's Avatar
yah my remote rolls down the windows (stumbled upon that one day by accident) mines a 99SE.. ive heard that a double pulse with the key in the drivers door would do the same thing, but so far i have been unable to reproduce this.. ohh well i guess aftermarket window modules here i come!
Old Mar 8, 2004 | 07:20 PM
dark_II's Avatar
i have a 96 Gle and if i unlock/hold the button my front windows roll down
doctorpullit
Mar 29, 2016 11:08 AM
pears
Sep 18, 2015 05:25 AM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
