Got my VBmod today, bought this tranny cooler and I need to know if its the right....
Old Mar 10, 2004 | 07:16 PM
NISMOMAXMAN's Avatar
So I got my tranny cooler today (from Mobiletek), now I will install it tomorrow afternoon, and tell you guys about it, anyhow I bought the tranny cooler from Hayden. BUt I got this part number 514 for 49.99. Is this a good size? I bought it at Autozone, do I need a bigger one? Thanks everyone
Old Mar 10, 2004 | 07:38 PM
Torgus's Avatar
uhhh...so you ment to say you got your vb today and bought a hayden tranny cooler. what size is it? 514 is no hayden transmission cooler i know of...they are usually 402 403 404
which ones of these are it?:
http://www.bulkparts.com/MM001.ASP?pageno=1181
also they probably have it cheaper...
you should run a 403 or bigger inline with the stock cooler. depending on how many miles you have a transmission flush can be good. also have you considered buying new Solenoids for it before you install it?
which vb did you get? there are different kinds/stages...
good luck with the install it's really not too hard. after getting the vb mod it makes driving an auto soo much more enjoyable. let us know how it goes...
Old Mar 10, 2004 | 07:47 PM
BadKarma99-4spd's Avatar
find out what gvw(gross vehicle weight) it is rated at, your probably fine but make sure it can handle the 3000 lbs our cars weigh
good luck
Old Mar 10, 2004 | 07:56 PM
Crap sorry guys I got the VB mod from Mobiletek. It was the upgrade, I didnt know they came in stages, if it did I'm assuming I got the weekend racing/street racing stage. Anyhow my car has about 144,000 miles, the tranny cooler is a Hayden 'High Performance transmission oil cooler" this is what it says:
part number: 514
Thickness:3/4"
Height:10"
Length: 15 1/2"
Core: 12"
Fitting: Screw-on
there are two other series of tranny coolers
Rapid-Cool Transmission Oil Coolers
and
Ultra-Cool Transmission Oil Coolers
"part numbers go from 676-679, and 401-1015)
Old Mar 10, 2004 | 08:00 PM
Autozone should have the 403 right??? I hope so, cause I need it buy tomorrow!!!
Old Mar 10, 2004 | 08:01 PM
Autozone should have the 403 right??? I hope so, cause I need it by tomorrow!!!
Old Mar 10, 2004 | 08:07 PM
Torgus's Avatar
Hayden Transmission Cooler kit
# 1405 Heavy duty driving, trucks, class "A" motor homes
GVW to 26,000 lbs.
10" x 15 1/2" x 3/4"
#1405...$34.44
that is one big **** cooler. i added my vb around 130k i did a flush and the vb had new solies in it...i reccomend it can only help the tranny having nice new fluid. you could even fiill it with B&M trickshift if you had the $$$...
your cooler is huge...install the cooler 1st!!! not after the VB. honestly getting a tranny cooler in correctly is a pain in the ****, least it was for me. more so then the VB install imo.
good luck. if you have any questions ask.
PS: i have a 403 and some 4gen guy with a vb said he has a 403 and lives in florida and has had no problems...403-404 is gravy. run them inline.
Old Mar 10, 2004 | 08:10 PM
-=PK=-Maxima's Avatar
so which cooler should we get if we got a vb upgrade? the 405? i thought it was the 403.
Old Mar 10, 2004 | 08:16 PM
Torgus's Avatar
a 403 or 404 will be fine. run it inline with the stock cooler. unless you think some day you might want to tow something huge behind your maxima a 405 is silly.
Old Mar 10, 2004 | 08:18 PM
what if youre s/c your car? will a 403 404 still be ok?
Old Mar 10, 2004 | 08:23 PM
Torgus's Avatar
yes
why not get a 405 if your worried....but i think you would still be fine with a 404...those things do alot of cooling....and your stock on is still cooling as well...
Old Mar 10, 2004 | 08:25 PM
cool.....thanks!
Old Mar 10, 2004 | 08:29 PM
Aight, well I know for sure I aint gonna be hauling anything, so what I'm ok with the little tranny cooler?? (if not I'll get the bigger one) My mechanic is gonna install the VBmod and the tranny cooler at the same time, I'll mention to him to put the tranny cooler first. Any other suggestions besides the tranny flush?
Old Mar 10, 2004 | 08:49 PM
Torgus's Avatar
oh i only say the cooler 1st because it was a ***** to install. also it holds about 1/2 a quart of fluid so once you install it you have to top up your tranny fluid...and your going to lose a good amount when you drop the vb...make sure he cleans the magnets at the bottom of the tranny pan...what else...i reccomend a flush cuz your going to refill about 1/4 of the fluid...maybe more...
good luck. OH!!! change the filter on the VB buy a new on or have him do it. they usually come with a gasket too. if you installed this yourself you'd save cash and feel alot better about yourself...its really rather simple imo.
peace
Old Mar 10, 2004 | 09:14 PM
cooler size will be the least of your problems if you have a super charger on your auto tranny
Old Mar 10, 2004 | 10:59 PM
RS Motorsports's Avatar
has anyone run just an after market tranny cooler and not inline with the stock one?, the reason i ask is b/c If I run it inline it comes way to close to the turbo piping and melts it, i have had to replace the line 3 times and decided to just go aftermarket cooler. Do you think by doing this I could run into any problems?
Old Mar 11, 2004 | 03:55 AM
Jime's Avatar
I bypass the stock cooler althgether and just run the aftermarket one. I have run at the track for two years now with it like that.
Stock one is a joke anyway in comparison.
Old Mar 11, 2004 | 09:19 AM
C MAX's Avatar
i have the b&m tranny cooler, best for the money.. im also running a s/c
and nitrous set-up 100 shot, with the stage 3 valve body. the tranny runs perfect. http://members.cardomain.com/whoamax
Old Mar 11, 2004 | 11:17 AM
Torgus's Avatar
C MAX- you forgot to mention you have a built lvl 10 auto tranny. these guys don't.
thats a huge difference.
Old Mar 11, 2004 | 11:29 AM
hey c max.......what are your times at the track?
Old Mar 11, 2004 | 12:07 PM
C MAX's Avatar
oops ! sorry.. its been in there so long i forgot, but i just recently put
the valvebody stage 3 upgrade and b&m tranny cooler 1 month ago at maximumtuning. i was running 300hp easy with just the level 10.
i didnt run it that hard until last year when the comp got tough.
Old Mar 11, 2004 | 12:11 PM
C MAX's Avatar
i havent tracked it yet? will very soon. but i'll tell you this when i hit that gas pedal, all i hear is oh, my, god, oooooh my god!!!! im hoping
some sick numbers soon, so i can post.
Old Mar 13, 2004 | 07:28 AM
97MaximaSE's Avatar
I totally bypassed the stock cooler but then again I have a B&M with bypass valve. Anywho i have about 130000 miles now with no problems so it must have worked. Ive always wondering if I should have run it inline with the stock one though.
pktaske
May 6, 2016 07:49 AM
nbstriker10
Sep 4, 2015 04:26 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
