I have an idea....can you put a little breather filter on......
Old Mar 15, 2004 | 04:22 PM
ManualMaxima's Avatar
5th Gen till she dies!
i have a mid pipe that was made from peice of rubber. and like the do it yourself mid pip shows, you can do only two tubes and but a breather filter on the tube that is right on the engine( hope you know waht i mean).
when you make it you are left with 2 tubes. One is a little line and the other is a bigger one. The bigger one follows into the back of the engine bay. Could you put a breather filter on this?
reason i ask......i can get breather filter from my frien cause has acouple laying around. so no charge. and i want to make one out of 3inch exhust pipe. And if i only had to drill one hole for the barb sitting wouldn;t that make it a little easier and maybr create a better air flow cause you do nto hav to to worry about the larger opening.
just a thought that i might try.
Old Mar 15, 2004 | 04:59 PM
mzmtg's Avatar
Minister of Silly Walks
No, you can't do that.
That is the tube to the idle air control valve. this must behooked up for the engine to run properly.
Old Mar 15, 2004 | 05:21 PM
Sin's Avatar
Sin
Even if you could, I wouldn't. That air is being ingested after the MAF, which means it is not being metered, which means, your engine is sucking in more air than the computer thinks, which means, it is running lean, quite possibly lean enough to cause enough heat to damage the engine.
Old Mar 15, 2004 | 07:14 PM
oh okay thanks befoe i made a big mistake!!!
Old Mar 15, 2004 | 07:49 PM
BSwithTF's Avatar
I tried this once before I knew exactly what all that stuff did. Car wouldn't run. It'd start and immediately die. Live and learn.
JoshG
51
Sep 21, 2015 10:41 PM
iamute
Sep 20, 2015 05:22 PM
bumpypickle
Sep 20, 2015 08:22 AM
thenewguyy
Sep 12, 2015 11:12 AM
Maxboy23
Sep 4, 2015 06:04 PM
