For Those with Bad 02 and KS
Old Mar 16, 2004 | 06:32 AM
RideTheMax's Avatar
I was getting codes for front right 02 sensor and KS. I had the 02 sensor changed out yesterday. (after mzmtg and I broke his tools trying to get it out because it was cross-threaded into the hole) anyways, my point is that a bad 02 sensor causes the ks error to come on. the dealer put in the sensor which I bought from oxygensensor.com for a lot less than what they want at the dealer. they reset the ecu for me, so when I get home I go and check the ecu because I didn't tell them about ks (granted they probably figured it was coming up anyways) and I wanted to see what would happen. I check the ecu and the ks code comes up. so I'm thinking maybe it is bad. I drove it around town some last night, and this morning, come home and check the ecu again. 0505 code, all is clear. SWEET. anyways, just thought I'd give you guys with both codes some hope and maybe save you some money.
Old Mar 16, 2004 | 07:23 AM
Brudaddy's Avatar
Thanks for the info.
What about if mine is spitting out the 0505 code (I checked a few days ago) but it has a hesitation like it is almost missing at WOT at about 3400rpms? Any explanation for that?
Old Mar 16, 2004 | 07:27 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
that could be the coil packs......
Old Mar 16, 2004 | 07:48 AM
s0ber's Avatar
Disconnect you knock sensor, drive it around, if you feel like a slug all then your knock sensor is fine.. =o
Old Mar 16, 2004 | 08:10 AM
happyricefob's Avatar
V^___^V
O2 always trigger knock sensor. when the O2 is fixed knock sensor should go away, if not, they u definetly have both malfunction O2 and knock sensor.
glad to hear everything is working out fine
Old Mar 16, 2004 | 08:35 AM
RideTheMax's Avatar
0505 means you should be all good to go. I don't know a lot about cars so maybe someone else can explain the hesitation problem. shouldn't be your ks tho
edit: maybe you have a loose throttle body cable. I saw some guys tightening their's a few weeks ago at the track.
Old Mar 16, 2004 | 09:26 AM
Brudaddy's Avatar
Anybody know a thread or link for instruction on how to tighten a throttle body cable or something related that might help the hesitation at WOT?
Old Mar 16, 2004 | 10:16 AM
RideTheMax's Avatar
If you look at your intake and follow it down to the throttle body, there are two cables. There are some nuts at the end of the cable. See if these are lose. If so tighten, if not leave them alone because you don't want to over tighten anything so that you break something.
Old Mar 17, 2004 | 09:12 AM
Brudaddy's Avatar
cool, thank. I will try that out.
I just keep asking about the coils and knock sensor, because I don't want to have to buy them if they are not bad. Obviously, as both of those things are pretty expensive.
Old Mar 17, 2004 | 09:38 AM
astil's Avatar
I learned that one the hard way...Or other words ,abter I replaced 2 O2 sensors and a KS sensor...At least the car runs great now...
Old Mar 17, 2004 | 10:02 AM
RideTheMax's Avatar
That does stink, but look at it this way, you shouldn't have to buy another 02 or knock sensor for a really long time (hopefully never). I'm at 90,000 miles, I'm sure the others will go out soon enough.
Old Mar 17, 2004 | 10:19 AM
Turbo1er's Avatar
Doin' it 4 da shorteez
I just went to a dealership yesterday to get mine checked out. They said Nissan is recalling the o2 sensors for the 96's at least, I didnt check if it was for all 4th Gens, so I am getting the o2 sensors replaced free of charge.
Old Mar 17, 2004 | 10:45 AM
Brudaddy's Avatar
cool, would you mind checking if it is for all 4th gens when you go back?
Old Mar 17, 2004 | 12:14 PM
Deagle's Avatar
wants the ads to die
Thats good to hear about them doing it for free. My car pulled the codes the other day. I checked my haynes manual and it said both up and downstream o2 sensors where bad plus the knock sensor. Is there an official recall or something official saying its free of charge?
Old Mar 17, 2004 | 12:52 PM
Turbo1er's Avatar
Just did a search on the Nissan web site and it does not show anything so it looks like it just pertains to a specific VIN range. I will check it out when I pick my Max back up.
Old Mar 20, 2004 | 07:41 AM
RideTheMax's Avatar
Bad news...
So I went to the track last night. Still ran crappy times 15.9-16.2
This morning I go check my ecu and there is a bad KS code. What I don't understand is why after changing the 02 sensor code, the KS code went away. I got the 0505 code and everything like two days later. Here not even a week later the KS code is back.
I hate sensors!!! HaHa, seriously tho, any thoughts?
Old Mar 20, 2004 | 11:37 AM
PharoNDmist's Avatar
I pulled 0304 from the Ecu and sometimes the CEL comes on then goes off,would that be my knock sensor or is it the o2 sensor tripping the KS?
Old Mar 20, 2004 | 12:11 PM
sagamax's Avatar
Give me a Bud Light Holmes
where is the knock sensor. i think mine is bad i feel like a slug at times
Old Mar 20, 2004 | 04:39 PM
Zamorskii's Avatar
oh man, you don't even want to know
look here, there are pictures where it is and how to replace it http://www.motorvate.ca/mvp.php/507
Old Mar 20, 2004 | 08:06 PM
zealotnyc's Avatar
are coil packs the same thing as ignition coils?
what are some other symptoms of coil packs and/or ignition coils gone wrong?
Old Mar 20, 2004 | 09:29 PM
mzmtg's Avatar
Minister of Silly Walks
The KS is a large part of your problem. That and that huge stereo and all the tools in your trunk...
Old Mar 20, 2004 | 10:58 PM
minsbang's Avatar
I got the code P0133, from Autozone. They checked my CEL and P0133 is for front 02 sensor. But I have no clue which one i have to buy at oxygensensor.com
Can anyone help me?
I posted a thread about my problem and i want to buy the 02 ASAP.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
