Engine noise at cold start up help...
Old Mar 19, 2004 | 12:42 PM
chrisZ's Avatar
Hi,
I read some time ago that there is a fix for a noise that is heard from the engine bay during start up when cold. My max has about 100K miles on it and started making this noise. From what I remember the replacement (tension adjuster?) is fairly cheap from the dealer, but the labour is involved. I have never seen the actual instruction on how to replace the part. Does anyone have these instructions posted anywhere.
Sorry if this was mentioned earlier in the forum, but you ust don't pay attention until it affects you.
Old Mar 19, 2004 | 01:04 PM
XeroX's Avatar
Hella internets
what noise is this? what does it sound like?
Old Mar 19, 2004 | 03:36 PM
NissanSE98's Avatar
sounds like your starter-if its like a bzz sound that last for a second-take apart and regrease
Old Mar 19, 2004 | 09:25 PM
vortechpower's Avatar
i have a 99 and it just started making that same sound. sounds like ****. i know that its not the tensioner pulley cause i just put a new one on. its def something that needs greese or something. maybe the alternator, i havent figured it out yet
Old Mar 21, 2004 | 06:52 AM
chrisZ's Avatar
I'm convinced that its a timing chain noise. I found it listed on the TSBs. Does anyone have the Counter Measure chain tensioner and guide installation instructions?
Thanks,
Originally Posted by chrisZ
Hi,
Old Mar 21, 2004 | 07:15 AM
Kevlo911's Avatar
Kevlo for President
Dealer charged me 200 to get it done.
http://forums.maxima.org/showthread....t=timing+chain
Old Mar 21, 2004 | 09:16 AM
pimpin99max's Avatar
http://forums.maxima.org/showthread....t=timing+chain[/QUOTE]
I am hearing a similar noise on my 99 max. Its a humming noise from the engine only on cold starts. It last only a couple of seconds.
Old Mar 21, 2004 | 09:41 AM
Kevlo911's Avatar
Kevlo for President
Does it go VEHHHHHHHHHHHHHHHHHH?
Old Mar 21, 2004 | 10:25 AM
Str8ballin's Avatar
My car does the same thing but I think it is the idler pulley. Sounds crappy but it goes away. Can't find a pulley now where so I don't know what to do??
Old Mar 26, 2004 | 11:38 AM
does anyone else have any idea what this maybe and/or how we can fix it?
Old Mar 26, 2004 | 11:52 AM
ChrisA's Avatar
if its from the timing chain area, then it is the chain tensioner. cost is around $50-70 for the part. its pretty easy to do. i think $200 is fair to have it done though if you don't do much on your car.
we had a good discussion of it last fall when i did mine if you can find it in a search. Stephen Max helped me a lot.
I may have some old pics I can dig up.
Old Mar 26, 2004 | 11:54 AM
MaximaPower's Avatar
try re-greasing the starter first
http://www.motorvate.ca/mvp.php/516
maxinout93
Oct 27, 2015 01:29 PM
bc992164
Aug 26, 2015 12:19 PM
FlaMark
Aug 21, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
