Daniel B Martin
Old Mar 18, 2001 | 03:51 PM
TrsMaxRacing
the rpm gauge still isnt working., the car is running finebut the rmp gauge doesnt work. Do you have any ideas??? I went to nissan but they gave me B\s so i left, any help appreciated!!!Thanks
Old Mar 18, 2001 | 05:47 PM
Daniel B. Martin's Avatar
Tachometer troubleshooting advice
Combination Meter is what Nissan calls the instrument cluster, the assembly which includes the speedometer, tachometer, fuel gauge, temperature gauge, along with a slew of indicator and warning lights. There are three connectors on the rear face of the Combination Meter: M82, M83, and M84. M82 is situated near the speedometer and fuel gauge.
You may backprobe connector M82 at the rear of the Combination Meter. M82 is a white plastic connector with 14 positions. Viewed from the harness side, identify terminal #3 which is in the upper row, third from the left. The wire at terminal #3 is white with a green stripe. Measure the voltage between terminal #3 and ground while the engine is running. The factory service manual says the voltage should vary in direct proportion with engine RPMs, but does not provide any specific values. If the voltage you measure at this point fluctuates wildly, that indicates the defect lies "upstream", probably in the wiring between M82 and the ECM. If the voltage is steady but the tach reading is erratic, the defect lies "downstream", in the combination meter assembly and possibly the tachometer instrument itself. The delicate Flexible Printed Circuit connection in the combination meter is a potential trouble spot. Cracks and cold solder joints in the Combination Meter printed circuit board could also produce this symptom.
CKNY
May 2, 2001 08:58 AM
CKNY
Apr 29, 2001 07:40 PM
B.C.
Apr 18, 2001 11:20 AM
ericdwong
Apr 10, 2001 08:38 AM
tonymich
Feb 8, 2001 09:22 PM
