O2 sensor removal??!!
Old Mar 26, 2004 | 07:24 AM
maximabebe's Avatar
Is there any way to remove the necessary O2 sensors for Y-Pipe installation without the sensor removal tool? Also, if using the removal tool is necessary, where can I grab one? Autozone perhaps? I have to be at work today at 2 pm and its 10:45 now, so far I got all 6 14MM bolts loose and I'm working on the 2 cat. converter 12 MM's.
Old Mar 26, 2004 | 07:35 AM
MrEous's Avatar
^ Jeff™
You can probably get it with an open-ended wrench but moving space will be highly limited.
You can get the sensor tool at Autozone fairly easy too.
Old Mar 26, 2004 | 08:24 AM
mansurxk's Avatar
unplug the sensors, remove the cat bolts and take them off after you have removed the ypipe, its a joke getting them off with an open wrench after that
the connectors should be right in front of the engine, someone should have a picture in the FAQ's
Old Mar 26, 2004 | 09:05 AM
RideTheMax's Avatar
You can rent the tool from autozone, etc. for just a deposit of the price of the piece. return the tool, they return all money. it's as easy as that.
bbsitum
Sep 6, 2019 07:31 PM
bumpypickle
Sep 20, 2015 08:22 AM
ac max 92
Sep 17, 2015 07:35 AM
