Firewall Getting threw the firewall
Old Mar 27, 2004 | 09:22 AM
stang233's Avatar
Hey guys I am going to be running some wires and some other stuff threw the firewall and was wondering were you all thought the best place to run the stuff threw was. I do not really want to have to drill a new hole so is there an opening that you guys already used. Please let me know where it is at. Thanks Rich
Old Mar 27, 2004 | 09:38 AM
I30tMikeD's Avatar
behind the splash gaurd in the front drives side wheel wheel there is a spot. You have to remove a rubber seal to get through it. I bet there is an easier spot, but that is what I used for my VI wiring
Old Mar 27, 2004 | 09:49 AM
talisman311's Avatar
If you're car's auto, go through the clutchplate, from inside the car and underneath the dash, it's in the upperleft, look for a diamond shaped piece and just pull that off of the stock padding, drill through that. Make a dimple using a screwdriver and make sure it's in the area you want it to be in. Should be good to go from there.
Old Mar 27, 2004 | 10:26 AM
DCM Maxima's Avatar
Thats were I went through(clutch plate) easiest way to do it but you gotta drill.
Old Mar 27, 2004 | 12:04 PM
stang233's Avatar
Dang Im a manual
Man thanks for your help but I have a 5spd. Any other ideas guys. Thanks Rich
fastcarny
Oct 12, 2015 07:06 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
